Note sure if these hot spots are an indicator they need replaced...
I just did the front axle rebuild with the C.O. kit right after I rebuilt my motor. I didn't have any leaks or wobble but the clicking had me alarmed. I swapped sides but the clicking came back. Makes me think the PO already swapped. Im not planning on rebuilding again until next fall whether I need it or not (the clicking annoys me). I would rather spend my $ with Slee (local to me) than the rainforest site or Hired Gun Offroad, just not sure of the quality. It appears the Slee version comes with the ABS ring and the rainforest site version may does not. (this is only based on pictures). $450 for anything is a lot of money to make a mistake with. Any advice from the forum on brand is appreciated.For a while, I even saw them on Amazon... Here's Nitro: Amazon.com: FJ80 HD BIRFIELD & AXLE KIT FJ80, FZJ80. (91-94 ALSO REQUIRE 43421-60040) FITS ABS: Automotive
If the year is '95 or later, here's another one from Nitro: Amazon.com: BIRFIELD JOINT ONLY (REPLACES OE 43405-60070) 95-97 LC FJ80, FZJ80 INCL ABS (USES TOY43421-60040 FLANGE): Automotive
gsi18867, I am probably not the best person to answer technical questions as I consider myself a newer owner (<5 yrs).
I wish I hadn't put this knuckle rebuild off for as long as I did... I've had some bad wobble when breaking at higher speeds and I'm still nervous about the heat marks, but if that's normal I'll reuse them. I've had it for about 4 or 5 years and saw some leaking about the same time I learned what to look for.
If I could offer any advice to other Cruiser owners it's this: "Don't put it off!" I'm replacing every bearing, seal, race, and gasket with a kit I bought from Cruiser Outfitters part # FA9097 and I used the (less expensive) Timken bearings.
I also found the Timken bearings and seals for the rear, and I'm doing that part next (hopefully tomorrow)... along with new rotors and brake pads, plus new shoes for the e-brake. I also selected the ARB Diff Breather kit as we get a lot of rain during the monsoons and inevitably, the kids coax me into taking them out to play in the mud (see profile pic).
I am not the most experienced mechanic, in fact, I've never done this level of work on my LC before, and partially avoided it out of fear I'd **** it up. I'm very glad I took 4 days off to do this, hopefully I'll have a free day left to take it out and test drive it on a trail.
Also the wobble could be the rotors. I am in the middle of my front end rebuild & am doing new rotors & pads as well. Had a REALLY bad wobble/shake when breaking. Thinking it was a combo of bad rotors (they had burn marks on them where the pads had scarred them), old tired bearings, & bad axle seals that had gone a long time back. The only think I am not replacing is the birfields, I hope switching sides does enough.
