FZJ-80 Stereo
Niceville, FL
My new-old 97 FZJ-80 has a factory installed stereo (radio, cd, cassette) with 8,yes 8 speakers and I haven't heard a worse sounding stereo since driving my Mom's 69 Buick LeSabre. I looking for anyone who has any ideas on upgrading this system. Can the current installed radio function well with new speakers and/or a power amp? Any suggestions?
Mine has 9 speakers. I have replaced 5 of them and added a Sirius Starmate 4. Everything else is stock and it sounds a heck of alot better than it did.
Seek (search) and you will find...
The paper-cone speakers are the weak link.
Do some searches on this forum; there are many ways to skin this cat.
The stock stereo is horrible at best. The head unit is OK,if you have something other than stock speakers. The stock speakers will make you cry.
There are 2 threads on this website that discuss upgrading the stock speakers, good stuff for sure. As for the head unit, go Crutchfield.com and find out what fits, not only in the car but with in your budget as well.
Just about anything thing can in the spot of that head unit, however, the speaker enclosures are a little tricky. If you want the "stock" look, you're going to be limited to 4.5" speakers with a very shallow mounting depth. If you're willing to break the factory covers you may be able to go 5.25 on the front and 4" in the back. As for the cargo area, it's anyone's guess.
Find those threads and you will on your way.
Good Luck!!
...f you're willing to break the factory covers you may be able to go 5.25 on the front and 4" in the back. As for the cargo area, it's anyone's guess....
there's room for 5.25"s in the rear doors with very little modification.
I run an aftermarket deck with 4 x good quality 5.25"s in the doors and a small (7") powered subwoofer behind the second row seats, and it's the best sound of any vehicle I've owned.
If were going to take the doors apart to install speakers this time, i'd add sound deadening mats behind the speakers for a more efficient signal. I'll probably do that this summer.
I must have tin ears. I have always thought the OEM radio was quite good...:o
My Land Cruiser came from a used car lot that someone took the front door speakers and (ripped)the grill covers off. I had a gaping hole in my front door panels and put the Pioneer 6.5 speakers from Best Buy in there. One of the posts here had the speaker installed behind the door panel w/ spacers to retain the stock speaker grill. Mine were torn out so I mounted them on the topside of the door panel w/o spacers and it fit. I was able to use the aftermarket covers this way. They are the Pioneer TS-G1641R. The older post said they were the TS-G1640R but it's the same speaker. Just updated the part #. They sound really good w/ the stock radio. Put alot of mids and bass in the doors.
Just got in from installing a new head unit ... Kenwood from Crutchfield. Replaced the stock speakers soon after I got it, and the improvement was HUGE. The new head unit makes a big difference as well, though not as much as the speakers did. So start with the speakers.
Replacing the head unit was very easy - aside from the general PITA of working behind the dash with big hands. Crutchfield gives you a wiring harness that you connect to the wiring harness on the sterao. Then it's just plug-n-play. There's an extra set of connectors behind the dash to bypass the factory amp which won't work well (at all?) with an aftermarket head unit.
There's a bunch of good head units out there. Let me know if you want to sell your oem unit. ;)
I'll sell you mine. The CD player doesn't work though! :D
FZJ80 Stereo
I moved the stock 6" rear subwoofer and amp out and installed it in my center console in the lower console. Then I unplugged the tweeters that are in the front dash. Stock headunit and stock speakers. It actually sounds great. The bass is there now and everything is filled and balanced perfectly. I think the bass is set at +6 and mid is like -2 and the high is 0. Listen to everthing from hard and classic and prog rock to alternative rock and it sounds surprisingly well. And it was free minus the labor of moving the wiring to the front then wiring it under the shifter and up through the bottom of the console which I had to remove to drill a hole through the bottom. Also had to take the metal bracket that holds the sub and cut the one tab that sticks way out then bend the other two tabs perpindicular so I could fasten the bracket to the inside of the console. Great sound for free. Stock speakers are fine. Just my $0.02:beer:
I completely re-did the sound system in mine, 6.5" Kenwoods in the front doors and 4" Pioneers in the rears, and disconnected the dash and rear tweets. Added a 920 watt Kenwood amp powering dual 10" MTX Thunder subs, capped the whole thing so doesn't kill my battery again... :doh:
97 FZJ-80 stereo
I complained on how bad the factory stereo sounded. Then I started thinking----Toyota went to the trouble of installing nine speakers and a fair amount of equalization and THIS is the resultant sound? No way! I decided to look at the speaker condition and-- lo and behold-- the "woofers" (1 in each front door and 1 in the rear quarter panel) all had rotted out surrounds. These speakers were producing 0 bass and a fair amount of distortion. I have removed these speakers and have ordered replacement foam surrounds. I predict it will sound pretty good when I'm finished. I'll let ya''ll know.
--Mike E.
--Mike E.
Methinks this is too much work for not-so-good speakers. You're probably going to be very disappointed in the sound quality. But then again, who knows.
Good luck.
:cheers:
The factory system sounds pretty good. They do wear out though. Mine is still practically new. :)
I recently replaced the front speakers in my 80, and it was basically a hassle and a half.
You're probably not going to find speakers that fit at a regular electronics store(i.e. Best Buy) because the stock speakers are reverse, basically. The magnets are mounted on the inside of the speaker enclosure, and the cone faces the magnet, instead of out.
I got the thinnest speakers Best Buy had, Pioneer, and because of the way the speakers are, you're either going to have to cut out the window track(and lose the ability to open your windows.....), or have the speakers mounted on the door panel instead of the door.
And this is just the front speakers.
I had to pop off the panel to get a 9 or 10mm wrench in to take the screws off of the speakers. I think it was 9mm.... And then I had to use a small prybar to take the speaker cover off of the panel. I screwed holes into the panel where the mounting brackets are and then used 12 x 1 screws to put the speakers where they needed to be. I then used glue to put the covers back onto the door panels.
If I were you, I would try my best to find speakers that are the exact dimensions of the stock ones.
And don't be fooled, they aren't 6 and 1/2" speakers, they just look like it.
I still haven't done the back ones yet....
Stereo difference on the LX450
Is the stereo speakers the same on the LC and the LX? When I read about stereo I never know if this applies to my LX if the person is talking about LC.
Rami
