- Joined
- Aug 24, 2014
- Threads
- 2
- Messages
- 4
Damn this group is good...but I have a burnt fusible link. I may have it tracked down to the alt/regulator. I have searched some other posts on this subject but am still confused a bit. My terminals are still good so I may only replace the link wire. It appears this circuit is 10 ga. wire so I'm thinking the link wire should be actual fusible link wire in 14 ga. I may not use the fusible wire and just install a circuit breaker which will be the square type or slow blow or whatever you call it. Is the 14 ga. fusable link wire the correct size? How many amps actually run throught this circuit assuming the charging is working correctly? What size circuit breaker should I use if I go that route? Thanks for the help.
