eBay Fully Custom Built 1972 FJ40 Land Cruiser
Northern California
Website
www.facebook.com
Custom Built 1972 FJ40 Land Cruiser (Price Reduced to speed sale)
Fully Custom Built FJ40 Toyota Land Cruiser
This Cruiser build was recently completed and has
less than 3000 miles on the build.
No expense was spared and you are looking at years of
countless hours spent to get this cruiser to what it is today.
I appreciate your time for looking at this truly one of a kind vehicle.
Watch Video:
Video
Ebay auction started: 1/18/2013...
Ebay Link:
http://cgi.ebay.com/ebaymotors/FJ40...STRK:MESELX:IT&forcev4exp=true#ht_2616wt_1234
Exterior:
Fully metal finished prior to paint
1976 Windshield Frame
Front bumper built into an air reservoir which features a water drain and is setup for a Warn Winch (Winch was Stolen)
Rear bumper made from 3”x 5” ¼ wall tube and features a trailer receiver with flat four trailer wiring plug
Hood Shaved: Took off the wind shield hold down latches and resting blocks
Under the fenders and hood got sprayed with rocker shutz for added protection and sound dampening for comfort
Upgraded Head Lights
LED Tail Lights
Custom Front Turn Signals
New Complete Best Top Soft Top with full or half doors
Body Armor made of 3/16 steel diamond plate and then Powder Coated in Hammer Grey
Custom One Off rocker guards are made out of ¼ diamond plate and Powder Coated Hammer Grey
All most everything assembled with Stainless Button head Fasteners: All were polished before installing
Interior:
Rebuilt the floor and got rid of the hump in the middle of the floor( not the dog house) plasma cut the floor and welded in new steel did the same with thing with where the fuel tank used to sit
Custom built dash made out of 10 gauge and powder coated in Hammer Grey
All New Water Proof switches in the dash
New Auto Meter gauges
Kenwood Stereo system plus 600 watt amp
Tilt Wheel with Borgeson Steering components
Billet Steering Wheel with a leather grip
Custom Built One Off Billet Accessories including: Head Light Switch Knob, Steering column levers, and Shifter Knob
LED Interior Lights
Custom built full family roll cage, stereo speakers are built in with wiring ran inside the cage
Sprayed the inside of the floor with bed liner spray
After Market Interior Heater
Custom Bucket Seats
Factory Fuel Tank was removed and a custom built tank built for installation between rear frame rails. 1/4 Plate was used for the bottom of fuel tank for added strength and safety
All most everything assembled with Stainless Button Head Fasteners: All were polished before installing
Most parts were powder coated before installing.
Drivetrain:
Fully Built 350 CI Chevrolet Small Block with w/ Edlebrock projection (multi Port) Fuel Injection
Advance Adapters Bell housing for transmission
Advance Adapters Rear transmission mount and Motor mounts
Completely Rebuilt Toyota landcruiser 4 speed transmission: All new bearings seals and syncros
Advance Adapters Heavy duty Orion 35 spline 4:1 Transfercase
High Angle Drive line of Paradise, CA New long slip front driveline, New CV Rear driveline
Stock cruiser axles with 4:10 gears
Front and Rear ARB Air Lockers with ARB Compressor
Also has a York Air Compressor for On Board Air System
All new 12 Circuit Painless Wiring Harness
All sensors and computer are new
Optima Yellow Top Deep Cycle Battery
Suspension and Handling:
Spring Over Axle Lift
Cut and turned the front axle 12 degrees to allow for proper pinion angle and proper factory caster angle
Custom built steering rods with hyme joints
Front shackle reversal: DOM tubing used for the frame rail sleeves
All new Rancho bushings through out the rig
New Rancho RS9000 Shocks
Rebuilt Brake Booster
4 wheel disk brakes with all new brake lines and Stainless flex lines: Toyota Front Disc Brakes / GM Conversion Rear Disk Brakes
Saginaw Power steering conversion: With Power Steering Cooler
Rims: 5 - 10”x 15” Chrome
Tires: 5 - 35x12.50 BFG Mud terrain
$36,950 Includes shipping to the lower 48 U.S. States
Contact:
Email: Cruiserinnovations@gmail.com
Phone: 530-966-1300
did this get any bids over $20k on ebay in last auction??????
The best offer made so far was $22,000.00. The cruiser has been up for sale for about 2.5 months now. There is substantially more than $22,000 in parts and service receipts alone on this cruiser build...
wow-22k.....id have jumped on that if i were a seller. Wrong color and an odd build with stock axles are mainly reason this is probably not selling. Lots of gearing and lockers on stock axles doesnt make sense....but im sure theres someone out there who will want to tackle the axles and make this a properly balanced rig. I find it hard to believe theres anyone out there who will want to sink another $few thousand$ into axle upgrades on top of a $25k+ entry point no matter how much they like yellow and no hard top.:hhmm:
I am not bashing but maybe factory turn signals on the front fenders and factory rear late model lights in the back bumper(loose the **** rear lights) and some widened stock steelies with hubcaps would make the rig look pretty nice and broaden the market?? Nice work but as anything this far custom from stock limits the audience because our vision is not always someone else's. nice attention to detail. GLWS
Bunch of things I like. The color is great, IMO and the contrast with some of the gray is nice. Bunch of things I don't like, diamond plate, home-made dash, turn signals and tail lights, bestop, optima crappy battery. I, too, would be jumping at $22k if I were you.
Wow....rough crowd :)
I can see where there has been a lot of attention and $$ put into this rig. I agree with Eddy that there are things that I like and don't like about this FJ. Obviously, it will take a special buyer for this vehicle.
Here is my .02 on increasing your likelihood of a sale. (I have a bit of experience with exotic cars)
3 things about Ebay
a) "Buy it nows" are worthless
b) Setting a reasonable reserve and disclosing it in the description will get you more bidders. Most serious buyers look at reserves and figure that there is no reason to bid because the seller is not going to be reasonable anyway.
c) Pictures are everything: While you have tons of pictures of the outside of the vehicle, there are virtually none of the inside. I find that details to the inside are the last thing that a builder pays attention to...if the inside looks good, likely the rest of the vehicle has been paid attention to as well.
GLWS, it is a nice rig!
Doc
3 things about Ebay
Doc
General cruiser pricing and ebay pricing goes something like this:
add 50% of the cost of all parts
add 50% of the cost of all labor
add $3k for cruiser with no hardtop
subtract 100% of cost of guages/dash and all diamondplate
subtract 100% of cost of labor for guages/dash and all diamondplate
and you have your final price you hope to get.
subtract $5k and you have your opening bid price.
So given the above math----im guessing:
bidding should start at $11k (to get some action going and peak peoples interest)
with buy it now at 18k (for the oddball lover of all that is yellow and diamondplated polished turdiness.)
and action should get some 14,5-15k winning bidder battle
Motivated to sale...
Really? Then go NO reserve and let the market tell you how much it's worth... diamond plating, incorrect turn signals, dash...etc. You're dreaming at 30k +. I'm thinking half that if you're lucky.
I look at the 40s market everyday and consider myself a serious buyer. When I saw this a couple of months ago, I thought way too ugly and has too much personalization to interest most. I agree, I would have jumped on $22k. In todays market and economy, I figure total all your costs, except labor. Deduct any personalization items cost that have only appeal to a select few, then divide it by half. That also works with the classic car market, unless you have something very rare. Overall, I agree with Dan Watters, you might get $15k. Sorry, but most builds you lose your butt.
I would have loved this Cruiser when I was 14 back in the early 90's. Unfortunately the way you have built it is going to appeal to very few Land Cruise lovers. If you can get a solid offer anywhere near the 20k mark, take it and run.
