Fuel Tank question?
TRAVERSE CITY
I Had 2 fuel tanks in my JF40. I took the auxiliary tank out and I'm am trying to figure out what fitting on the tank goes to the carb..... Sorry for the dumb question, but I am lost...
@05TDUSSEAU :
The one coming out of the center of the driver's side of the tank, shown on your pic, below.
If you follow the line, you can see where the P.O. put a valve in the line.
I seem to recall the line you’ve referenced as the RETURN... the fuel pickup (FEED) is on the same side, closer to the rear of the tank and low down on the tank.
I’ve looked around and the only “plumbing” diagram I can find is for the CCOT Replica tank.
The diagram is shown on this CCOT page and here it is... zoom it in:
It’s difficult to follow the lines in the OP’s pictures, but I think you’re correct that the valve is on the line you mentioned... but, I think it’s the return line.
I suspect it’s plumbed to allow the driver to TRANSFER fuel to the MAIN tank, from the AUX tank, by opening the valve.
But, I’m not sure, without knowing just how the feed and return lines are plumbed.
Edit: To be clear, on my ‘78, OEM routing was:
- the FEED goes to fuel filter, then to the fuel pump, then to the carb inlet
- the RETURN goes from the carb return, DIRECTLY to the tank-return.
What I know, for a fact, that on my 1973 FJ40 with a stock fuel tank, the connection I identified is the supply connection to the fuel pump.
I know this because when I disassembled it for my restoration project, that's where the line went.
Since the second connection you refer to doesn't show up on the OP's picture, I don't think it exists. Maybe it does, the OP will have to check.
I can't speak to the CCOT tank, or for tanks that have supply and return lines to the tank.
I guess the OP should also post his month/year of manufacture to clear things up.
I am very new with 40's, so...
It's my understanding the feed and return are on the driver's side of the tank, as solace post indicates.
It looks like your feed is currently run to the return with the valve.
The CCOT tank is supposed to be a “replica”... I don’t have any experience with the CCOT tank... it’s supposed to be for 9/72-12/78
But, what I know for a fact is... their diagram matches my memory, of what I started with before I redesigned my fuel system. So, it matches my 01/78.
But, I stand corrected, the valve IS on the FEED line... the pickup originates where I said... but, from underneath the edge of the tank... just as the CCOT diagram indicates
So, my new theory is, for some reason, a PO installed a manual shutoff valve on the main tank fuel feed line.
The feed line originates at the fuel pickup, runs to the valve, then turns down, thru the floor, WITH the return line.
You’re correct, we need to know the mm/yy manufacture date and the market it for which it was manufactured.
Thanks for the input guys. I won't be working on it until the next few days. The diagram should be very helpful. Ill let you know my findings!
The line with the shutoff feeds the carb. The line that goes to the return in the tank comes up to the firewall and is cut off with a bolt thought it. What is the return for if it’s not hooked up or in Circuit?
Still waiting to hear your answer to “we need to know the mm/yy manufacture date and the market it for which it was manufactured.”
I have zero experience with a fuel system that has NO return to the tank.
I don’t know where unused fuel goes, without a return.
Does your carb have a return connection?
Pictures of your carb & fuel pump would help.
@73FJ40 did I understand you to say that you are familiar with fuel systems that have NO return to the tank? Would you please explain where unused fuel goes, with no return?
@Solace in Solitude
Gee, as far as I know, all FJ40's in the USA through Feb 1973 production dates only had single fuel line systems.
The move to return lines, I believe was to alleviate vapor lock in the fuel lines, do to the higher under hood engine temps resulting from pre-catalytic converter emissions schemes.
Given the following illustrations from the OEM parts fiche, which all feature the supply line coming out of the side of the tank like mine, and like the picture that @05TDUSSEAU posted, the natural assumption is that his supply line was similar to all models up to 1973. Since we don't even know his month/year, USA domestic or import, I guess we have to wait on him to fill us in with the rest of the details.
7109 - 7209:
6903 - 7109:
I've got a stock 2-'75 40 that I purchased new. And I really don't know much about this issue...BUT... It would 'seem' to me that a fule line that feeds the carb would be at the bottom of a tank and not at a middle point. Thoughts??
That’s what I thought as well. That’s where it is on my 01/78... and that’s what @Poser said, 3 posts above, about 9/73-12/78.
@73FJ40 has a ‘73, with the fuel feed port, centered on the DS of the tank... he provided a diagram, above, that shows this.
We still don’t know the manu date for the OP’s truck. But, his pictures show a tank similar to mine.
So, is that why I always run out of gas when the fuel gauge indicates half full?
OMG, why did it take Toyota until 1973 to figure this design flaw out?:rofl:
On second thought, maybe they figured the take off point for the fuel would be better up off the floor, where you could get to it without pulling up the tank.
Inside the tank, of course, there's a pickup tube routed from the side wall fitting to the floor of the tank.
Any more info on this? Years? Don’t see anything about this in the F engine repair manual.
on edit: I’ve found a few posts wrt this line, but they are generally later years. Also, one thread mentioned a filter on the end, is that stock and for what years? Seems like if stock that’d need to be a serviceable item and mentioned in the FSM or such. So I guess I should see if I can get my’63 line out and check what’s there. Makes sense there should be a tube otherwise it’s really a ~8gal tank lol.
Info on the part if you have it.
@73FJ40 FYI @middlecalf
Re “Inside the tank, of course, there's a pickup tube routed from the side wall fitting to the floor of the tank.”
Are you sure the pickup line hasn’t fallen off inside the tank? That would explain why you are only able to use the top half of your fuel.
My 22gal aux tank has the fuel feed at the top of the tank, with a pickup tube to the bottom.
Assuming your fuel sender matches your fuel gauge and is calibrated properly, the mid-side feed, with a pickup tube would be fine... and would report correctly.
There is great information HERE, for <= 1972 (discusses how voltage is dropped for fuel measurement) and MUCH more pertinent info (all years) HERE.
