Fuel tank “cushion”
Plant City, Florida
part 77652, fuel tank cushion. There was none on mine when I removed the tank. Now putting it back in and want to make something. Does anyone know how thick it should be? I have some hypolon mat approx 1/8” thick. What do you think?
^^ok I’m guessing this is TIC? If so, I like using iron oxide. If not, seriously???
This is what I came up with. 1/8” reinforced rubber hypalon.
I by no means know what is stock or "right". When I removed my tank there were 3 or 4 strips in the corners that went up the sides. Putting pads on the bottom will isolate any rattles against the bottom, however, you might consider doing something up the sides too. I'm still a month at least away from putting my tank back in, but plan to do that.
mine had strips up the sides you need to keep the tank from rubbing metal to metal.never one for a 10 point resto i always used cut up inner tubes for the strips
Mine had carpet in there and replaced with strips of generic rubber weatherstrip
