Just finished converting to four wheel disc and decided that next up would be a carb rebuild (currently a Weber 32/36) as well as freshening up all the fuel lines and making steel lines where I can. I have a 1/75 2F motor in my truck. As I was looking things over I realized that I have what looks to be a 1/79-84ish fuel pump. Didn't know the newer style pumps worked with the older motors, but okay. I guess my question is should I bother building metal lines or just stick with the rubber ones on there? It seems to be working fine with the weber. I would kind of like to hook up a fuel return line off the weber though as I believe I saw in one of Weber Sarges posts that if you have the return off the Weber carb it eliminates the need for the fuel pressure regulator I currently have inline. Should I ditch the current pump and order the correct style? What would the advantages be?
