Fuel System Question
The Trollhole is pretty simple , just requires the stock heat insulator between the carb base and the intake and the stock air cleaner and linkage setup correct for your truck . The linkage can be an issue as some Weber kits had a gas pedal/cable kit that replaced the original and sourcing a complete pedal and linkage/cable can take time to find a good one . Otherwise , the THC carb runs excellent .
Sarge
Sarge
I have a Weber 38, and as @Weber Sarge has said - the OEM or a @Trollhole carb are your (ours and mine) best bet. I have an order in to Marshall for one of his cable linkage THC carbs. Weber Sarge & @Pin_Head both gave me a lot of help trying to resolve issues with my Weber 38..... And I still came to the conclusion that when a guy with the handle "Weber Sarge" recommends running a THC on a 2F... LISTEN to him! LOL, I/ve just been stubborn.
Well I guess that makes it easier than running a return line all the way from the carb. I wonder if running the return line from there though will make my Weber still operate properly? Or will the fuel pressure reg still be necessary.
I installed the return filter, very easy. No pressure issues. I don't wheel it hard - intentionally, so I've been OKish with the Weber 38 - but will be swapping to the THC carb after the first of the year.
I've written volumes about doing mods to the DGV series Weber carbs for both cars and offroad rigs - the worst "kit" is for the Land Cruiser since it has a crap setup for the throttle linkage whether it be cable or solid links . I prefer if possible to mount the carb with the float bowl in the rear to prevent fuel slosh when climbing a steep hill or obstacle - without a complicated system of bellcranks and such it's almost impossible to do correctly on the F engines . None of the DGV carbs will feed even a 1F enough cfm , including the 40DFAV - it would take at least a 42DCNF and those start at about $500 for the carb alone , no kit . The mounting kits are a joke , with cast aluminum -chrome plated intake adapters and the crappiest cardboard gaskets . There is no way they will seal correctly and not warp/bend with a few heat cycles . Also , those plates are never close to being flat - most are off by around .080" and some well over that - vacuum leaks for sure . Unless you lap the plates flat and use a much thinner gasket they usually end up over time warping the base of the carb - this is extremely hard to repair and correct . What you end up with is a carb that won't return to base idle correctly and a lot of leakage at the floating throttle shaft on the primary side .
I have some very specific and protected ways of fixing the fuel slosh issue - built over 300 carbs with a modified vent system so they would run at extremely high angles with no idle or flooding issues , but that work is expensive since most of carbs that came in had issues from the start when they were cast (Spanish castings , not from Italy) . Last new casting I saw was worse than ever , quality has disappeared in this new age of competition . If it were a Samurai or Toyota mini truck I'd recommend a Weber or still a stock desmogged Toyota carb on the smaller (less than 3.0L engines) 4 cylinder engines . Otherwise , get a Trollhole or rebuilt Aisin .
Just to clarify so I don't get a ton of new emails - I no longer work on Webers , gave that biz up a few years ago .
Sarge
