Fuel Pump Outlet question
San Antonio
Quick question about what to do with the outlet nipple on the fuel pump. I am replacing the old pump and the new one has the outlet nipple at the 2 o'clock position vs the 12 o'clock position (straight up) as pictured below. It has to be straight up to fit into the the fuel line going to the carb.
My question is do I tighten the outlet nut until it is straight up or do I loosen it (turn counter-clockwise) appox 315 degrees so it is straight up.
I know it is a simple and likely silly question but I have never installed one of these before and I do not want to damage it.
My truck is a 1974 FJ40--Cali-Spec.
we have the same outlets or To the carb side fittings
Do Not straighten it to the 12 oclock position , Or like me u will have a Leak Post assy. because u will have unscrewed the J.I.S.
Pipe Taper just enough to do so .
it is correct to be in the 2 Oclock position , your hard fuel line should be bent at a approx 15 degree angle in order to meet the 2 o
Oclock position
post a photo of your fuel line " hard " to see if it still has the correct bend or not ?
Here are photos of my to the carb from pump line and also of the pump I am replacing.
A few more pictures of the old fuel pump in place--you can see the fuel line going straight up from the pump.
Take a piece of hose, with a close inside diameter to the hard line outside diameter, and split one side, end to end.
Slip the split hose over the hard line and carefully bend it to match the angle you need.
Don’t force it, just slow, even bends.
If necessary, make multiple bends, to prevent a single sharp bend... you don’t want a crimp in the line.
RAGINGMATT and Solace in Solitude, thank you. I appreciate your help and advice. I am happy I resisted the temptation to rotate the fitting--I have learned the hard way that waiting for help when you are clueless is best.
I will certainly consider using the rubber hose trick get bends into the line. Has anybody had any luck with a specific bender for the 5/16 tubing--I would need the tool to be compact enough to bend the tubing with it in place.
Assuming it is damn snug in its current 2 o’clock position I’d turn it counter clock back to 12. If it leaks go to plan B. As you know the threads are tapered so they seal good.
I wouldn’t start bending just yet. You could also try a different threaded elbow. Do you have a spare elbow? If not I probably have a couple I could mail you to try.
I have not started bending yet. And yes, it is very snug at that 2 o'clock position. I suspect I'd have to gently lock the fitting into a vice and rotate the body of the pump counter-clockwise.
I do have the elbow that is still in the old pump
On a slightly different note, I am replacing this pump not because it has gone bad, more of a pre-emptive change given that I don't know how old the pump that came with the truck when I purchased it is. I figured given the engine compartment components I currently have out, changing the pump would be a good idea. Question is how could I tell if the pump that I have taken out really needs to be changed? Maybe I should open up the old one and clean it out and keep the new one with my stock of parts I have for future need.
Here’s a couple 1/8 BSPT to (M13?) 90’s. Both at 12 O’clock. 3 or 4 threads showing.
To test, put your finger over the inlet nipple or outlet and pump the arm in a couple times. If the diaphragm is good, you’ll feel suction against your finger. If cracked, no suction.
I’ve taken a couple pumps apart. It’s a cruiser owners right of passage IMO:hillbilly:. Since you have new pump in hand, I say tear into the old one and inspect. If the diaphragm is brittle and tears during teardown, it was due to fail. Might as well find out now.
There’sa few pictures in this thread
fuel pump rebuild
thebigredrocker, as usual, very generous with your knowledge and time, thank you. Are the elbows the same threading and pitch on the pump housings for the 2 pumps (i.e. the housing with the 12 o'clock positioned elbow and the housing with 2 o'clock positioned elbow)? The reason I ask is that if they are, tracking down an elbow from an old pump and placing it in the place of the one that is at the 2 o'clock position on the new pump might be a good plan. What do you think?
I think I’m understanding your question. Your old and new pump should take 1/8” BSPT inlet and outlet.
Both my spare fitting are 1/8” BSPT on the pump side. I think the fuel out line side is straight M13. It’s not tapered pipe it uses the barb and compression nut like yours.
Is this what you mean by 12 & 2? Right or wrong, I add a dab of oil on steel to aluminium connections. I think a dab of fuel rated PTFE is ok also.
3 is fuel out
7:30 is fuel in
Here’s two of the fitting I have.
Your 1st picture with the 12 o'clock and 2 o'clock positions is what I am referring to--i.e. the orientation of the outlet elbow. To be clear, I have taken a picture of my 2 pumps side by side and illustrated on them what I mean--I should have done that sooner, it would have made it a lot easier.
In your 3rd photo, the one on the left looks like the outlet elbow I would need. If you can spare it, I would love to purchase it from you.
I believe the solution is pretty straightforward. Remove the fitting, wrap it with two or three turns of ptfe tape, and tighten to the 12 o'clock position. Don't overtighten, fuel pressure is only a few psig.
Also, keep the tape away from the first thread or two of the fitting. You don't want any of it heading downstream to the carburetor.
If you're leary of the tape, go to the store and buy a sealer compound compatible with e10 gasoline.
Why do you need it in place? It is easy to remove. When I made an all new line I got a Tekton Amazon Prime bender. It's cast aluminum and impressed me. Tricky to get used to though and awkward to hold both ends but also keep the tube oriented how you want it while you clamp it in. A friend to hold things in place would help. I patterned off the old one
Actually I just looked and its not Prime anymore but this one is.
