fuel pump rebuild
Chico Ca.
Im getting ready to rebuild by original fuel pump but can not seem to find the thread on a prior thread showing step by step. IDK why i cant figure out search engine. could someone please help find the thread to the early early style fuel pump rebuild. thank you
Bottom plate. With screws removed you may need to gently tap around the plate to break the seal free. Take your time so as not to tear the gasket
Plate removed. Take note of center ridge orientation.
Gasket off. I believe some pumps have just 1 outlet valve and 1 inlet valve. You may have to clean crud out of the valves. Debris/Crud will not allow them to close.
Now for the pump diaphragm. Take note of your fuel in/fuel out port orientations.
Gradually loosen the screws. Do not fully remove them. Leave them all partially threaded until you break the diapragm free.
With an old pump you'll need to gently tap around the edges to break the seal. Once the seal is broken, the two halves will pop open but will be held by the screws you partially backed out
Now seperate the two halves
Now you'll need to unhook the diaphragm rod from the pump arm. Push the diaphragm in with a good amount of force and twist it 90 degree's. Now the rod should be off the pump arm
You'll now need to spin the diaphragm rod so that it makes its way through the keyhole shown below
Install in reverse order. You'll need to summon a bit of brute strength when compressing the spring as you put the screws back in. I gradually tighten each perimeter screw to acheive even pressure on the diaphragn. Sorta like torquing lug nuts, use a star pattern.
Once together, put your finger over one of the fuel line ports. Pump the arm a few times. When you remove your finger you'll notice pressure is released, indicating your pump is probably ready to install.
this is why i remember someone having to thread something else to make it work. i think they had to switch shafts and install with treads since it is crimped in originally. the ends are not compatible. do anyone have info on such?
