So quick update. I am convinced that the FSM is wrong with the 55 ohm spec between posts 1&2 (as indicated in the FSM) . There are now too many examples in this thread showing the resistance to be 25 ohms to ignore. My original gauge,
@g-man @poptart gauges, and now a donor gauge that I received and tested today (was known to be working when it was pulled). I just filled up so it reads perfectly—I just filled up and have driven about 15 miles. I’ll be reporting back as I go through the this tank of gas and the readings on the gauge.
Donor gauge connected to my truck today
Resistance test on donor gauge
So what is the problem with my original gauge? Maybe the voltage regulator in the gauge? Interestingly though is where the donor gauge needle rests on the “E” when the key is off (which looks to be the correct way), my original gauge needle falls all the way to the bottom of the gauge, well below the “E”.
