Fuel Filter....is this overkill?
Kansastitty
I am getting ready to swap in a 2F that I recently rebuilt. Currently I have no fuel filter before the fuel pump. I do run an inline glass filter right before the carb. Anyway, I'll keep the inline filter but thought about installing something like this. My 40 year old tank has been cleaned and lined, but crud in the fuel has caused me problems before.
It certainly can't hurt. I use a similar throw away filter and I can always til when its time to replace same; cruiser starts running crappy...
I like the idea of a canister filter, a kinda big one. They(Summit) list them for either FI or carbed motors. I was worried about resistance of the filter and no pusher type pump like in FI, so I assume the one designed for carburetted motors has less resistance. I think my '66 originally had a sediment bowl, but I like the idea of a filter.
Thanks,
Ed
I have one like that on mine. I knew I had to get rid of my aux tank when I had to change the filter every fill-up. The can had about an inch of rust scale in the bottom of it, too.
Mine is the kind that you unscrew the can and change the filter inside.
When I fuel injected mine, I used this filter before the fuel pump.
That is pretty much what the stock fuel filters look like for the F135(which i am running). I also run another filter right before the carb, can never be too safe I guess. :D
andrewfarmer said:
On mine, I run a diesel filter with a water trap/tap/sensor in it.
Works fine, lets me easily drain any water that gets in there - plus I get a warning if there is water in it.
That's what I was looking for when I found the one from Summit. Most of the diesel ones I've seen were huge. Have you got a source for the one you used?
I like the idea of the water trap, too. Although I guess the one I found would also trap some water at the bottom.
Ed
