fuel economy
you did not mention the tire size or your driving habits. larger tires will change the fuel conomy, sometimes drasticly.
driving habits can really make a difference.
type of fuel you are running as well as any brake drag is another problem.
have you done a compression test? dirty injectors?
need more info...
Good Day.
Being a geeky type of owner I have a spreadsheet for mileage on my BJ73. I have a 5 speed and stock 215/80-15 tires. My driving is unfortunately mostly rush hour Vancouver commuting. I get a solid 24.6 mpg (Canadian gallon) or 11.5 l / 100kms for those politically correct folk. This is a 3 month average. And yes - I work with a bunch of engineers.
Roman
Hi there
Well
If I had fiques around 10-12lt per 100 I would be happy.
My BJ73 runs a 2H Diesel and I suspect its getting a little tired but returns figures 16-17lt per 100 (some times higher). I also run 33" tyres but didnt thing slighlty bigger tyres would make alot of difference?
Well my view only
All the best
Wayne
you guys are lucky. i have a 2LTE LJ78 with a 20lit/100kms. i have new injectors. had a compression test done, i forgot the reading but the diesel centre said it was ok within limits. thats the main reason i want to change the freakin engine. :C will it be worth it to have the fuel injection pump calibrated first?
Do tires make that much of a difference? My BJ74 uses on average 10.5 liters/100km with 33 inch tires and my hilux 2L diesel around 11.5km/100km.with 15/235
I would think the tire width, tread profile, and weight would effect fuel economy more then tire height.
No way in hell should you be getting 20l/100km on the 2L-TE. I get about 10.5 on the highway, maybe 12 around town.
Money says you've got drivetrain issues, brake drag, etc.
thanks for your reply light duty. i'm 99% sure. its 40liters for 200kms give or take a kilometer or two. i always fill up on the same time of the night, same pump, same vehicle position. i have 235/85/16 AT's (yokohama geolander)
how do i check my drive train? i dont have excessive brake wear, the auto tranny shifts a little late to 3rd i have to get to 2400rpm for it to engage. (its a 3speed auto i think?) my first auto tranny. any suggestions guys?
All the calculations are great, but you should try to get a GPS calibration of your odometer to confirm your base numbers are accurate. You may be off more than you think. That of course assumes you can get an accurate GPS to work from. Some are more accurate than others.
This thread is not pertinent.
All you guys compare the fuel/km on a base of different engine ! 3B, 13B, 2H, 2LTE, 1HZ...
2H with 31" tires, HJ60. Mostly slow driving around town and dirt roads I rarely get under 11l/100Km, but usually do better than 13.
For example.
BJ74 Mileage
Vehicle is a 1989 BJ74 with 13BT engine, stock boost, with 12.5X33/15 Truxus Radials on 8" wide rims, PTO winch, Old Man Emu lift - all things that affect mileage. Conservative driving style.
GPS mileage corrected at 15%
Based on an average of 2,536 miles (July 2006 to December 2006) of about 70/30 town/ highway I got 25.9 mpg (imperial gallons), with a range of 23.1 to 28.5 mpg per tank.
1987 HJ61 - just drove 530 kms (measured by GPS) 31x10.5x15 tires.
Averaged 100km/hr for that time... going from Vernon to Vancouver via Kamloops. On the Coca-Cola highway, I was going like 100 to 125 km/hr to get my average up to that 100 figure.
Total fuel burned: 58 litres.
Mileage 10.9 L / 100km :flipoff2:
Needless to say, I am happy with that :) And it was 5th gear all the way on the Coq with power to pass on the hills. :cool:
