fuel consumption
i have a 76 fj45 ute and on the road it it has plenty of power but cruising at 45/50 mph i am only getting 10/12 miles per gallon
(imperial)my question is what should it be getting in consumption
your fuel consumption is going to depend on alot of things...tires, gearing, driving style and then what kinda shape your filters are in plus how tired your engine is....i was getting about 10-12MPG probably before a buddy pulled the carb off and put it togather correctly (the PO had TRIED to work on it) and with proper sized jets....i didnt drive it for long before i left but i was probably up around 16 maybe 18MPG after that...i did a tune up less than 1000 miles ago though and changed all filters, plugs bla bla bla....i have been told if you want better milage pull the hard top off and you will gain a few mpg or somthing...havnt tried this yet though
If I keep my vehicle speed between 55 and 60, my 45 will get between 14-16mpg. I run a 235-85-16 tire, which is about 32" tall.
I may try a 3:70 gear swap later this year to see what happens.
Hth
Mark A.
