Does anyone know the size of the small sheet metal screws that go around the edges of a factory soft top door? I'm taking apart a set of them and I've managed to only get about half of them off....the other ones have broken off.
Right, I can find sheet metal screws that may work but the head size is the key. If anyone has any suggestions for alternatives please respond!I find the part number for the sheet metal screws to be 93520-13010 and unfortunately are no longer available. Being sheet metal and not machine screws might search graingers or McMaster Carr. Because once installed the head is hidden by the weatherstripping just need to be sure the screw head is not any larger than stock to be sure you slide the weatherstripping on.
I think I'm going to have to try maybe a #5 sheet metal screw which are not on the shelf that the local Lowes or HD. I have some #4, but they're to small.I remember years ago there was talk that Toyota would reproduce a part if enough people could produce a VIN for the vehicle that needed that part. The discussion was about 16" non split rims. Finding enough VINs of 40 that left the factory with 16" rims never happened. In the US we have an advantage since all our FST models came with soft doors. I still have a FJ25 FST and FJ40 FST that are titled in my name. Not sure if Toyota has detailed records that far back but most my pre 75 FJ40s have model FJ40L on the VIN plaque. The V is not there. Because there is no OEM aftermarket replacement might be worth looking into. Pop rivets could work. Down side is once the door frame is drilled to except rivets would be major work to fill in the holes to use screws again.
belmetric.com
Thanx for that link! I think I was able to get what I think is pretty much the same thing from that site. I'll know for sure when they arrive and I'll update this thread when I do.Check Here:
Metric Screws | BelMetric Fasteners
Explore BelMetric’s selection of metric screws in top styles, sizes, and finishes. Find quality screws made for reliable fastening.belmetric.com
I have had some luck getting JIS and other metric hardware here that closely matches what Toyota used.
Thanx Beno....I did not know that. I just looked those up...holy smokes they are pricey for just one!93520-13010 supersedes to 90161-A0003 which are readily available.
If you don't like the OEM option, get out your calipers and measure one, then go to McMaster Carr and see what you can find. Anything you can ever imagine fastener wise is available through their online cataloge, and you'd likely get anything you ordered next day from their SantaFe Springs warehouse.Does anyone know the size of the small sheet metal screws that go around the edges of a factory soft top door? I'm taking apart a set of them and I've managed to only get about half of them off....the other ones have broken off.
Yup, that was the first place I tried since they usually have any fastener you could imagine, but I didn't see anything other than what I could find at a local hardware store. If the ones from Belmetric are comparable I'll post a picture of them next to the ones I pulled off and didn't have to break. They were only $.09 each. Not sure of the quality, but for $5 I'll see what they're like.If you don't like the OEM option, get out your calipers and measure one, then go to McMaster Carr and see what you can find. Anything you can ever imagine fastener wise is available through their online cataloge, and you'd likely get anything you ordered next day from their SantaFe Springs warehouse.
Did find it interesting Amayama shows them out of production when you Google the part number up easily comes as well as the other part number. Find these for under $1.50. This is one of these play to play parts wouldn't mind playing for. When I was younger it wouldn't been out of the question anywhere near that much.Pay to play.
They fit great! I purchased LOTS of them...I think it is like 40/door.93520-13010 supersedes to 90161-A0003 which are readily available.
I show thirty four per door.
Maybe that is why I got 40I say 38 (34+4) with a few extras… because let’s face it … you’ll drop a few and it will be too much of a bother to find it when it’s lost in oblivion![]()
