FSM question
I have a late model 1994 LC and just had the check engine light come on and it has started to run extremely rough. I have searched the forums and keep seeing "FSM" and can't figure out what ___ the abbreviation is for? I need to get it scanned to see the code.
Thanks
FSM = Factory Service Manual.
You don't need a fancy scanner to pull codes on your truck, you can do it with a paper clip.
10 bucks and this web site (techinfo.toyota.com)= FSM for a day.... just save/download what you want or all of the information for your 94' cruiser if you have the time.
Did this happen suddenly?
If so, check the air intake hose for cracks.
If you washed the engine or ran through enough water to splash up into the eigine compartment pull the distributor cap and make sure it's dry inside.
