FSM preservation
NYC / CT
Any tips on how to keep my newly purchased FSM from falling apart? It doesn't seem that sturdy and I plan to keep it on board so I'm hoping not to shred it up like my Haynes is
Put it in a vault and purchase a 2nd one to use :)
I've had my FSM since new back in Jan 98 and it seems to be hanging together just fine other than an oil or grease mark here and there.
cheers,
george.
If your like me, and plan to carry it along with you in the truck you could buy a slip case for it. Seeing what these FSM cost, i think a case is a good idea. Here is a link to a seller who makes all different sizes of slip cases. http://www.slipcasebooks.com/index.htm Now if you good at wood work you could always make a case out of wood.
I'm cheap, so the 3 things I did/do:
--Fold your own box to slide it in, leaving one side/top open. Use a ton of packing tape so it covers all the cardboard.
--Use contact shelving paper to cover the outer binding of the book, leaving 3-4" long flaps to fold into the insides of the cover both front & back. I have a roll of clear for just doing books.
--Anytime you're getting set to do a major/greasy job, take the book to your local office supply store & photocopy that section - 11x17" sheets cover the 2 open pages all on one sheet.
*Officemax is totally cool with me doing it, but Office Depot throws a fit - tell them you are just an end consumer & not for profit, and you bought the book so you bought the license to copy & use, it's true & legal.
For sections like front axle service, keep the photocopy (esp if you have drawers in back) onboard, we all know you'll be looking at it again sometime.
-----nothing here costs much, but in the ~12 yrs since buying my FSM, it still can sit next to my other books in the bookshelf & it isn't a greaseball or dogeared.
Get a @yodaTEQ gulllwing hatch system with molle panel for one (or both) third row windows, then fab a metal case with molle tabs to attach it to the molle panels. It's handy and keeps your FSM from getting the corners bent.
Personally, I have one on my iPad mini that I take everywhere with me. The hard copy doubles as a coaster on my desk at home.
They do not hold up. Picked mine up yesterday and about a 100 pages came out of the back of it. It sits on the bench or on the shelf in the garage. I was thinking about hole punching everything and putting it into binders.
Im really cheap much cheaper than Donald Trump is rich:worms:
FSM are poorly made and very difficult to keep clean in times of need.
I carry a thumb drive also DL to google docs with the FSM and every other manual needed for the electronic equipment in my 80.
Print the pages when you need them and you will no worries when you get them dirty because when it all over they go in the garbage.
For my old Honda I did similar to what Half K mentioned above. Hole punched the pages and put each section into its own binder.
Obviously you would not want to do it that way if you carry it in the truck. If that's the case just put it in one binder. For the purists a period correct Trapper Keeper is in order.
Thank you all. Will search the Web for a TMNT Trapper Keeper : )
I found a great work-around - I have an Amazon Kindle, it accepts PDFs (simply connect via USB, look for your Kindle on your computer and upload the PDF to the 'Documents' folder on the Kindle). On a Kindle you can search through the TOC like any book, and go to different chapters, leave bookmarks, it's very convenient.
It's great, durable, and v portable, and takes weeks to run out of batteries. I might have passed on the paper manual had I known I could do this, and I'd consider buying an older Kindle strictly for this purpose (prob around $50, maybe less) if I had neither since the Kindle is so easy to navigate, is pretty bomb-proof and no glare, etc. etc.
I have the 'paper-white' which illuminates in darkness, which is helpful because no matter how early I start most of my repairs go into the dark : )
HTH
Send your FSM to a book binder to have it bound with a more durable cover. Consider having it split into two volumes as (IMO) there are too many pages to be bound into one usable book and still open wide enough to be easily readable. Part of the problem in binding the FSM is due to the poorly glued spine, but a good book binder can reinforce the spine so it will hold together better. You can choose from a variety of materials for the cover; paper, cloth covered cardboard like a yearbook or library reference book (Buckram), or even leather if you want. Might cost something like $150-175 for two volumes in Buckram with a reinforced spine along with some embossed lettering on the front cover.
McSpadden Book Bindery - RESTORATION METHODS
Kater-Crafts Bookbinders, Fine Bookbinding, book and bible restoration, family owned, oldest and largest Library bindery in Los Angeles, Southern California
