FSM IM: distributor
tejas
trying to wrap my head around a couple things.
TDC is achieved when you turn the “crankshaft pulley” so that the marks on the guide line up with the 0 mark on the timing chain cover? what does the “crankshaft pulley” do? it’s mechanically tied to the crankshaft?
and then you /verify/ by checking the single dots on the two camshaft gears are aligned?
the verification is to see that the timing chain between the crankshaft and the camshafts is aligned properly or what? sorry massive noob status here.
also, what are you doing when you verify the distributor rotor is “arrow pointing up”? another way (besides using the camshaft gear fits) of checking to see engine is at one or another TDC? and i guess rhere is a registration mark on the distributor gear to make sure the distributor is tied properly to the - well i guess it is tied to the crankshaft?
THANKS
TDC is achieved when you turn the “crankshaft pulley” so that the marks on the guide line up with the 9 mark on the timing chain cover? what does the “crankshaft pulley” do? it’s mechanically tied to the crankshaft?
TDC (Top Dead Center) is the farthest position upward in the cylinder the piston will ever be. Before you remove the Distributor you want the piston of the # 1 cylinder to be at TDC on the compression stroke. You can do this by rotating the crank (via the crank pulley bolt) until you line up the hash mark on the crank pulley (also known as the harmonic balancer) with the (0) mark on the timing boss.
You will verify that you are on the compression stroke by looking at the 'rotor' underneath the distributor cap. It should be in roughly the 11 O'Clock position (pointing at the # 1 spark plug tower on the distributor cap...were it still in place). Yes, the crankshaft pulley/balancer is connected to the crank. In fact it must be torqued to about 302 ft. lbs for a number of reasons. The crankshaft pulley drives your belts that operate things like your engine cooling fan, alternator and A/C compressor but it also is balancer....helping to balance the rotating mass of everything connected to the crankshaft.
This not really necessary unless you have had head work done, were replacing a timing chain, etc....
IF you happen to mess up reinstalling the distributor....you'll likely just be what we call (180 out). If that happens, we can walk you through correcting that.
Expand for replies.
Expand for replies.
thanks a lot FK,
so TDC on this engine means what though? are the crankshaft and the camshaft turning at a 2:1 somehow or 1:1? i guess what i am missing is i am "used to" (really all i know) a "horizontally opposed" engine. so at TDC one piston is at TDC when you are at TDC on the crankshaft. and the other is at BDC (or whatever). hmmmm. i guess this is also related to the fact that the camshaft turns TWO times for each revolution of the crankshaft somehow....? anyway - if you see the side you are working on is not at TDC by checking if the pushrod can rotate (if it cannot you are not at TDC on that side...) you rotate one more time to "the other" TDC to get the side you are working on at TDC.
then there is a wasted spark since both spark plugs fire at the same time but only the one piston uses the spark since the other is at BDC.
but on this engine there are six cylinders.
so is one /side/ of the engine at TDC in one case when you have the camshaft gears lined up with the SINGLE DOTS aligned in the center with the camshaft pulley/balancer lined up at 0 and is it that the other set of pistons are at TDC when the DOUBLE DOTS on the camshaft gears are aligned in the center?
i have to sort of write this out even to figure out what i am not understanding so advance apologies if that does not make a hell of a lot of sense.
also, the distributor is firing /spark/ when it is at 11:00 and this is why you want to see the "arrow" in the distributor pointing at 11:00? is it that the lead for the cylinder #1 is at 11:00 is that right? or how is the distributor firing to the six cylinders is what i should be asking. it's divided into six equal increments and each cylinder fires by it's own within one revolution?
lastly, what is in that distributor please? it is not points. is it a sensor of some kind? or is it all electronically controlled by the ECU with circuitry or something?
massive noob status here but really appreciate your helping me get up to speed...
- jon
thanks a lot FK,
Yes, different in certain ways on all 4 stroke engines that are inline or 'V' configured.
Any two stroke knowledge you have can pretty much be dispensed with and 4 stroke horizontally opposed for the most part too.
So as not to write a tutorial on 4 stroke engines (such as the 1FZFE) I will just touch on some of the more important things with respect to the many questions you asked.
The four strokes that occur in one complete 'cycle' are:
1. Intake..... (intake valves are open at this time)
2. Compression..... (intake and exhaust valves are closed)
3. Power..... (intake and exhaust valves are closed)
4. Exhaust..... (exhaust valves are open at this time)
At traditional TDC the piston is at the very top of it's travel in the compression stroke. The intake stroke has already occurred and has brought a mixture of fuel and air into the cylinder.
The compression stroke is also the stroke wherein the spark plug fires to ignite the compressed fuel/air mixture just a bit before it reaches TDC. When the fuel mixture ignites the expanding gases drive the piston downward (this is what produces the mechanical work at the crank) and this would be your power/combustion stroke.
Then the exhaust stroke occurs, expelling the mostly burn't mixture. So you can see that in one complete 'cycle' the piston reaches it's upward most travel twice (once on the compression stroke and once on the exhaust stroke). If you were to install the distributor at TDC on the exhaust stroke (180 out) the engine would run terribly (if at all).
Since only one cylinder fires at a time (closely followed by the next in the firing order) it is important that this occur at the correct time (about 3° before TDC). The 1FZFE is an inline six cylinder. The #1 cylinder is the one nearest the front of the engine. The firing order (counter clockwise) is '1,5,3,6,2,4'. Other firing orders might have been possible..but Mr. T determined this one to provide the smoothest power.
The Crankshaft rotates twice for every revolution of the camshaft(s).
When removing the distributor we want to preserve the timing of the ignition...so we orient the engine at TDC on cylinder #1 and its compression stroke. It's just the easiest thing to do.
Also, you will note when removing the distributor...the rotor will twist slightly off the 11 O'clock position because of the helical cut gear at the bottom of the distributor shaft. So when removing it...note where that is and be prepared to put it at about the same place before re-installing it...because it's going to twist again (the opposite direction) when you re-seat the distributor.
IF you are off just a little bit there is nothing to fret about as we can mechanically adjust the timing to a certain degree.
As you've noticed...there are no old fashioned 'points' in the distributor. The ignition system is fully electronic.
If you get stuck somewhere in the process just post back with a RTH (Real Time Help) and someone will guide you through it. Also use the 'search' function as there is a cornucopia of information on the site. You can read to your heart's content on just about any subject concerning your Land Cruiser.
Expand for replies
Expand for replies
THANKS.
so one crankshaft revolution for every two of the camshaft revolution seems to be pretty standard for some reason that has eluded me. but i guess it is not a reason specific to a horizontally opposed boxer engines with a wasted spark - which i had sort of assumed.
on TDC.
there are /two/ camshafts with a three pairs of lobes on each for intake and exhaust for each of the pistons? is that right?! and the lobes are arranged on the camshafts and the conrods are attached to the crankshaft so that each of the six cylinders hits TDC at a different time? or is one camshaft for intake and one for exhaust i guess now that i take another look at it.
also can i please ask you what the single dots on the two camshaft gears is and also what the double dots on the camshaft gears is? the single dots aligned in the center are TDC for cylinder #1? are the two dots aligned in the center on the two camshaft gears - BDC for cylinder #1?
"so one crankshaft revolution for every two of the camshaft revolution seems to be pretty standard for some reason that has eluded me. "
It's still eluding you. ;) You keep getting that backwards. It's two revolutions of the Crank for each one revolution of the Cam(s).
On four stroke engines....the camshaft moves at 1/2 the crankshaft speed. This is good to know when trying to distinguish valve-train noise from lower end noise.
THANKS.
doh. the crankshaft is turning the pistons up and down once per every two camshaft cycles.
that lets the intake and exhaust valve open and close once per crankshaft cycle since you need the valve closed three times to once open. so you need two revolutions of crankshaft to each revolution of camshaft.
intake - intake open, exhaust closed
compression - intake closed, exhaust closed
power - intake closed, exhaust closed
exhaust - intake closed, exhaust open
so two more here please?
are there variations on this that don’t get too screwy like the wankel engine or whatever? or are all “four stroke” engines two crankshaft turns to each camshaft turn i guess?
also. the geometry of the crank and cam is such that the six TDC’s for the six cylinders is equally distributed around the 360 degree turn of the crankshaft?
Correct.
Any reference in the FSM to TDC is a reference to piston number 1 being at TDC on the compression stroke (all valves closed).
this is used to set timing of crank and cam so valves open and close at the correct time.
And timing of distributor so sparkplugs fire at the correct time.
Distributor is driven by the camshaft.
The 1FZFE is an overhead cam, multi valve engine.
It has two intake, and two exhaust valves per cylinder.
There is one cam activating the intake valves, and the other operates the exhaust valves
Yes, but No, some cylinders are paired on the crank.
When they are paired, one will be coming up on the compression stroke ( all valves closed),
and one will be coming up on the exhaust stroke (exhaust valves open)
Timing of valves and ignition is set to create as even a distribution of power strokes throughout one full cycle of the engine as possible.
As flint suggested, during order can be different in different engines even though things look to be the same.
An example is old school Ford V8s, Windsor vs Cleveland V8 had different firing orders which produced a noticeably different exhaust sound for both
Correct.
thanks all.
ok i see. two intake and two exhaust valves. and there are 12 lobes per camshaft. with one shaft for the 12 intake valves and one for the 12 exhaust valves.
on the timing. there is a crankcase position sensor i see at the bottom of the engine? this senses a magnet or something in the crank? and it feeds the ECU which tells the distributor to fire? what is the mechanics in the distributor? is it mechanically locates in reference to the cams with the gear, and theme it fires a pulse electronically somehow? or is there a name for the distributor in these things so i can check it out?
also please. the single dot on the camshaft gears locate TDC cylinder 1. but what is the two dots 180 degrees opposite? these would put cylinder 6 at TDC i guess?
thanks for the help here. not totally sure i follow. is TDC for each of the six cylinders equally distributed throughout the 360 degrees of the crank i guess is what i meant to ask.
No, look at the animation I posted. It shows two cylinders coming to TDC at the same time. In that example, one will be on the compression stroke, I've on the exhaust stroke.
If both were on the compression stroke at the same time, you'd get an unequal distribution of force on the crank during each revolution. The engine would not run smoothly.
thanks all.
ok i see. two intake and two exhaust valves. and there are 12 lobes per camshaft. with one shaft for the 12 intake valves and one for the 12 exhaust valves. Correct
on the timing. there is a crankcase position sensor i see at the bottom of the engine? this senses a magnet or something in the crank? and it feeds the ECU which tells the distributor to fire? Correct
What is the mechanics in the distributor? is it mechanically locates in reference to the cams with the gear, and theme it fires a pulse electronically somehow? Correct. The rotor button (arm inside the dizzy) rotates and distributes a spark to the correct plug lead or is there a name for the distributor in these things so i can check it out?
The dots on the camshafts are there to get the cam position/ timing correct if you have removed the head of timing chain.
all timing marks are setting timing of a particular rotating part in relation to number 1 Piston at TDC (unless the FSM notes otherwise)
Expand for comments
Expand for comments
THANKS mudgudgeon, @flintknapper, all
i will study the animation and the responses. i can lighten up on the questions if needed. it is just i get a chance to jump in once in while...
what is a “thrust clearance” with the cams? or what is the need to lift them out oriented horizontally and to lift vertically (i guess)? it is because they are in there so tight?
also, trying to find this illustration. is there any significance to the x marks on the distributor illustration?
Expand for comments
Expand for comments
Expand for comments
also, trying to find the illustration showing the cylinders and the distributor in the FSM. is there any significance to the x marks on the distributor illustration?
