FSM IM: distributor
The sketch diagram? I would guess it represents the screws that secure the distributor cap. The cap will only go in one position.
Search for IdahoDoug's head gasket replacement video
If you're looking at removing cams, you need to follow the FSM carefully. If not removed/ replaced correctly valve spring force can damage the cams
> If you're looking at removing cams, you need to follow the FSM carefully. If not removed/ replaced correctly valve spring force can damage the cams.
so can i put the valve cover back on and take the whole head to the machinist at that point?
also, was there some deal about zip tying the timing gear in place so the crank doesn’t move?
Electronic ignition system.
I think early fzfe used this system, spark timing is fully controlled by distributor.
later ones use crank position sensor which gives more accurate control of spark timing
interesting video! so there is an electromagnet (or electromagnets) in the crank which makes electrical contact with the sensor and it tells the ECU to turn off the electrical power at the ignition coil at some point (or points) in the crank rotation. this turning off of the ignition coil sends a high voltage spark through to distributor which hits the distributor contact for a particular spark plug lead which then fires the plug?
i mean the actual geometry of that i don’t exactly understand but sounds about right i guess?
As flint suggested, during order can be different in different engines even though things look to be the same.
An example is old school Ford V8s, Windsor vs Cleveland V8 had different firing orders which produced a noticeably different exhaust sound for both
Correct. Plus the Cleveland shared the same firing order with the 351M-400M engines as well. And older (non-HO) 302's had a different firing order than 351W's though the cams could interchange (by changing the firing order).
And you Aussies were lucky enough to have the 351C up until 1982 if remember correctly where we only had it for 4-5 years.
Also, Ford numbered their engines left bank 1,2,3,4 and the right bank 5, 6, 7, 8.
GM numbered theirs Left Bank 1,3,5,7 right bank 2,4,6,8. Then you had to figure out the firing order and make sure you're looking at the correct cylinder based on manufacturer.
Typical inline 6-cylinder I-Head engines have a firing order of Too Young, Too Old, Just Right. (15 36 24) There are some variances. Inline 4 cylinders can be 1,2,3,4, or 1,3,2,4 depending on configuration of the crankshaft.
V-6's are all over the place.
on the timing chain crank you just remove it and take off the head? and i run the head to the machinist? then you just need to make sure the mark on the chain lines up with the mark on the crank is that right? or was there more to it than that?
