Front windshield washer not working
Los Angeles, CA
My front windshield washer pump isn't working. I've tried replacing the pump with another one without any lucky either. The fuse is fine and the rear windshield washer pump is fine. I hear nothing when I try to use the front windshield washer pump.
Does anyone have any ideas of what the problem may be? It seems like it's an electrical problem... my next step will probably to take a multimeter and see if the plug is getting power when turning on the front windshield washer pump.
Oh yeah, I have a 1991 FJ-80 so there's no diverter thing like the FZJ-80.
If you haven't used it in a long time, or are using leftover detergent for the water, try poking the nozzles with a fine needle. You might not hear the pump if you're inside the cab.
Kalawang
I'm in the engine bay while I have my little brother turn on the front windshield washer, and I don't hear or feel anything movement in the pump... :(
Bad switch, have you looked at the connector for the pump for crud? Could also be a bad rotary switch in the column.
