FRONT WHEELS POSITIVE CAMBER?!?!?
Manassas, VA, United States
I know it is not possible to camber a solid axle but looking at my front wheels I see the top of my tires sticking out. like positive camber, also I seem to hear a roaring noise. kinda like a wheel bearing noise and the steering feels sloppy... suspension wise she's stock only mod is My tires : 305/70R16 Bridgestone Dueler AT and they aren't super noisy. what could be causing this issue? I'm seriously considering just selling this thing and go another platform. between the recurrent EGR insufficient flow code, non working Difflocks, and now this I'm about just disappointed with my purchase. even though I'm the second owner and the truck looks good I'm just blown about it. maybe I bit more than I could chew and didn't need that type of rig. ain't like there's places to go around Northern VA where I could use the legendary 4wd capabilities these trucks are famous for anyways....
Actually there are ways to camber a solid axle these days, but I'll get to that in a minute.
Your issue could be simple enough that I think it's a bit hasty to consider selling it off just yet. It's entirely possible that a wheel bearing is bad. This would not only cause the noise you're hearing but if the wheel bearings are loose or if they're bad enough that they're coming apart then that could cause the loose steerings and weird camber.
This is one of the wheel bearings I pulled from my Cruiser just after I got it and was chasing down some neglected maintenance. I didn't notice the camber problem you have but steering was loose and definite bearing noise. This was coming apart enough that it could have easily affected camber.
You could also have bad trunion bearings (knuckle bearings). Sounds to me like the front axle is just due for a full service to replace the seals and bearings. Chances are by replacing wheel bearings and trunion bearings and have the preload correct that the truck is going to feel and sound much better.
Since you're on stock suspension there isn't going to be a need for this but back to the camber on a solid axle..... There are trunion bearings available now with offset races that can be used to increase/decrease caster or camber depending on their orientation.
How much do Front axle services usually go for? I could do it myself but the HOA would have a fit like no other
