Front wheel bearing preload?
Olathe, KS
I did the front axle service about 1,000 miles ago and decided this morning to check my front bearing play. Per Romer's write-up, I jacked each wheel up and moved the tires from the 6 and 12 o'clock positions. Both wheels have a little play - not much, but I am still concerned.
During the axle service, I set the preload using a fish scale and if anything, it was a little on the high side.
So my question is - do loose bearings indicate I set the preload too high, or not high enough??
Wheel bearings
Check you front lock washers to make sure the tab was not sheared when you tourqued the outer nut. it shears pretty easy. I would say not tight enough.
Loose bearing indicates that the preload was not set high enough. If you want peace of mind, tear back into it and tighten it up a bit using your scale. Go to eBay and search for "push pull gauge." Chatillon makes a good one. Money well spent.
Hey El - man those Chatillons are expensive new. Looks cool, but I think I'll try a new fish scale first.
By the way - great job on the DVD, I used that for reference more than anything else on the job.
I had something similar to this awhile back. Whatever idiot worked on the DS birf before I bought it didn't fold the lock washer over both nuts and the outside worked its way to the end, and then the inside one started to loosen a tiny bit and I noticed a bit more play in it. I had to get new nuts and lock washer, etc. My question is, even though it was barely loose; in fact I couldn't tell for sure and took it off just ot make sure, could it have damaged anything by being a bit loose? It looks like they just replaced the birf and drive plate but the fools put the old seals back on. Anyway, thanks.
I would say you're fine, that first nut probably ran into the drive plate and just sat there. So now you've got new nuts, and a new drive plate, should be good to go, IMO.
And on the original post, I've had this happen too and like many I've ditched the fish scale and switched to the "feel" method. If it were my truck I'd jack up the tire, pop off the drive plate and first nut, give the inner nut about 1/8 of a turn then put it all back together and drive it. ymmv..
"Use the Force, Luke! Trust in yourself!"
After reading everyones experience with this, it's clear to me that
using the scales is no guarantee of success, so, might just as well
skip it and go by feel (still using a sensible procedure, of course).
You might have to go in again and adjust it, but that seems to be
true using the scale for a lot of folks anyway.
Spinning while tightening seems important. Read this thread and see what you think:
https://forum.ih8mud.com/showthread.php?t=94600
