Front SOA Spring Question
Olympic peninsula WA
So I am doing a SOA in the front of my 40 and i was wondering if i should pull the shortest leaf out of the spring packs. and if i do will the front end be to soft?
The springs are from a 76 parts truck and both the front and rear packs had 7 leafs.
Thanks
I initially ran mine with one extra leaf in the front....it's really all personal preference to the ride. They will flex similar regardless of leaf count. If you have the stock inline 6, I'd definitely keep them all for starters.
The F is long gone. It has a 351W now so it is a couple hunderd pounds lighter up front now.
My '76 original spring packs sagged quite a bit after the SOA - I took out the smallest leaf both front and rear and have since added leaves back into the spring packs.
I would say leave it in there even though you are a little lighter w/ the V8
I'de keep the full packs if you plan on doing a lot of traveling on the road with it. The springs will wear out faster when you start pulling leafs. Mark a.k.a. Helocat trashed his front springs on his 40 when he had to slam on his brakes to avoid a dear. He was running only 4 leafs I think.
I have front 40 spring front and rear and it sits at a good height . starting to sag a bit in the rear but I will make some shorter front shackles to lower the front end and keep the rig looking level
definaley keep the stock pack though they flex awesome as they come , any less leaves and these 30 year old sprins might decide to quit on you! and you dont want that
