Front rotor change again!
Kent England
Well I have finally got peed off with the violent steering wheel shaking that I have been getting the last 6 months, it gets worse when breaking in a long down hill road, the wheel wobble and foot brake are unbelievable, the hotter the rotors the worse it is, in the end the foot brake is going up and down violently and the steering wheel is shaking back and forth and gets so bad I have to stop braking and use the auto box to drop down to 2nd and 1st to avoid putting my foot on the pedal.
In the morning when cold, they are not to bad, but when hot, all hell lets loose!
I have now ordered proper Toyota rotors, the last rotors I fitted were non Toyota, perhaps fitting Toyota 100 pads to non Toyota rotors cause these violent problems.
I have also ordered new rotors the new tab washers and the washers that go against the bearings. I have not gone for the 100 series pads this time, I had lots of problems with clearance fitting the 100 pads last time, I had to sandwhich a 1/32" shim behing the caliper to get it central to the rotor, before I could get both pads in, all the parts cost £300
I do hope it is the front that is causing the problems and not the rears!!!! :mad:
Any suggestions that I should do and dont on a rotor change, just incase the last rotor change I done was not right.
If the steering wheel was shaking violently - then it is the front and not the rears. make sure your calipers retract easily and don't bind. A bound caliper will superheat a rotor and warp it.
If your caliper's pistons all move relatively easily, do not bind, and show no signs of leakage, don't waste your time and money rebuilding them. What you may want to check is the master cylinder... press the brake pedal down (while the brakes are all together and installed), and see if all wheels spin freely quickly after the pedal is released. This may be hard on an AWD, but I'm sure you'll be able to tell if there's brake drag. Anyway, if the master cylinder (BMC) is shot, your brakes will drag horribly because the BMC acts as the 'return spring' in the system to allow the pads to spread open again after braking. Once the seals leak, the fluid doesn't return quickly, or at all, leaving the brakes on even if you're not on the binders.
Make sure you bed in the pads with the rotors properly. You do not need to resurface rotors if you stick to the exact same pad the was used previously... but if anything about the pad is different, you should resurface the rotor to ensure that the brake material lay is consistent across the whole rotor. This will prevent glazing past the break-in period and prevent hot-spotting. By the sounds of it though, you probably want to either resurface your rotors or replace them... seems as though you have a highspot.
Hi Grench, I did do the bedding in process but done it slightly differently, I have a laser point heat gun and did drive the car with slight pressure on the peddle and kept stopping to check when it had reached the 280 temp, perhaps that was not the best way to do it, perhaps the stopping was not allowing the rotors to stay at an even temp.
I will do it the way the link suggests doing it see what happens
Hi Keros..... the wheels do seem to turn ok after putting the brake on, but being 4wd makes it hard to see but to me they are freeing off ok
Again?...How ,any times?...lol
Another thing to check are the bolts that hold the calipers in place. I had a similar issue. It turned out that one of the caliper bolts had been cross threaded and had basically stripped out and opened up the bolt hole only a few threads were left. So occasionally when I stepped on the brake the pads would catch and with the caliper lose it would shake like crazy.
The shop has just phoned to say the parts are in, so I will go and get them, not sure if I can change them today as the weather is quite crap :-( really want to get this sorted out, and I am back to work tomorrow.
If the weather brightens up today, I will have a go at changing them, even if I only get one side done, should not be a problem only doing one side, I only have to drive 10 miles to work and will take it easy
If the calipers have never been given some TLC, I'd suggest rebuilding them for couple of reasons:
- clean out the piston bores of old, gunky fluid. Bleeding brakes don't always clear these areas it seems.
- fresh grease (comes with the rebuild kit) on the pistons wouldn't hurt.
- complete system bleed down and then fresh fluid will go a long way of removing moisture that's prevalent in the UK!
- keeps you out of the pub, wife will appreciate that!
I don't have OEM rotors or pads and have never had any issues (with my other vehicles) and I don't see why they'd cause any issues for you either. I think your problems are elsewhere and a thorough rebuild of all calipers may solve them or at least force you to look closely at the whole system.
I put non OEM rotors and pads onto my 93 last year (they came as spares with the car when I bought it) and they've been sweet as. The rotors were "blue circle", not sure about the pads - it was a red and blue box - I could find out as the box and old pads are still in the shed...
I'd be suspicious of the calipers.... a rebuild is no big deal/cost for the peace of mind...
ATB - JB
I think a brake fluid change would be good, but I will do one think at a time I think, before I change the rotors I will check with a magnetic DTI are warped, before I change them, (will change them regardless if not warped)
If I still have a problem, I will then check the rears, ifthey are ok I will change the fluid and refurb the calipers
