G'day from Cairns, Australia.
I have a few oil leaks that I'm in the midst of fixing.
One appears to be from the gasket between the front-plate and the cylinder block. I cannot get to the bolts to check if they were torqued correctly when the PO put the motor back together without removing the crank pulley. I was hoping they might just need pinching to stop the leak - anybody had this problem before?
Also, I have the vehicle in gear, but the cranknut rotates slightly with the socket wrench - albeit with a little force. I was expecting the vehicle to have to move in order for rotation to take place, and the clutch was in good order when the vehicle was parked up. Any obvious clues as to what I'm doing wrong?
Also can anybody give me a torque value for the crank nut as my repair manual (not FSM) states 253ft/lb which is different from what I've read on this board.
All help appreciated.
Justin
Justin
