changed front pinon flange but didn't realize there is a crushed sleeve
did i mess up my front diff
yes i tighten the pinon nut to the marks i made before taking the nut offHow did you do preload? Did you just keep tightening the pinion nut? If so yes you will need to pull the 3rd and have the gears setup.
pinyes i tighten the pinon nut to the marks i made before taking the nut off
thanks guys for the informationthe only problem here is in theroy the new flange " depth" will not be the same as the old one longer or shorter possibly
- did u buy a Toyota OEM flange or a aftermarket one ?
- do u know what a pre-load guage or scale is
- do u have a FSM ( factory service manual )
- was there a torque wrench involved
I think you should be fine. I changed my pinion seal and just torqued it back to the same mark and it never failed me.
