that's good to know. some video's i watch didn't really show supporting the frame.. The Bolt on the passenger side is hidden behind the bracket, I can barley get my finder in to touch it
Driver side is nut & bolt, passenger side is bolt with nut welded inside bracket..that's good to know. some video's i watch didn't really show supporting the frame.. The Bolt on the passenger side is hidden behind the bracket, I can barley get my finder in to touch it
Driver side is nut & bolt, passenger side is bolt with nut welderd inside bracket..
The drag link can get in the way of the bolt on the passenger side, with the tires on the ground jack the chassis up tell you can get the socket on the bolt that it no need to hold the nut on the back side
As long as you only take one panhard off at a time you should be fine, in fact you my need that ratchet strip to get the last bolt in.
cool thanks, I think I'll go that route, wasn't sure if the whole rig needed to be lifted. Is there a nut that will drop from behind the passenger? Or is it a fixed thread? Appreciate the insightI lift the car 3-4” and support the frame (right behind the tie down points) on jack stands so the axles a little drooped out. It usually gives me enough room to get the passenger side bolt out without taking the tires off
The nut is welded to the backside of the bracket, so no need to worry there!cool thanks, I think I'll go that route, wasn't sure if the whole rig needed to be lifted. Is there a nut that will drop from behind the passenger? Or is it a fixed thread? Appreciate the insight
No problem! Good luck!whew....I could feel it with finger tips but I couldn't get a look at. This eases my trepidation. Thanks!
ThAnks for all the advice. Too bad I can’t even get the DS bolt of, breaker bar & impact wr, have been futile. Keep hitting it with anti seize. Maybe needs to soak overnight
