Front locker interchangability
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
Fro Sraha's 96 LX450, will a locker from a 94 work? I have the harness for the front for a 96 and not sure if that will mate to a 94 locker.
Got the Dash lights switch and ECU in. Lights all blink and it's sweet how the hole harness is there already along with connectors.
Next week will have the rear locker put in.
Yes the connections are the same. The harness routing is a bit different, that's about it.
Man, you have been all kinds of help today!
Thanks Dan.
:cheers:
You may have thought of this on your own but... you'll want to lock the locker before you install the carrier. Before you have the carrier in, install the actuator and connect the rear harness and slide the passengers side axle in and use the dash switch to lock the axle. ;) You can pull the axle back out but the collar will be in place and make it much easier to install the PS axle.
