Front locker actuator gear differences between years
Rogersville, Mo.
Recent trip had my front locker not lock up. Removed the actuator this weekend and its full of water. Will work on cleaning and rebuilding but for now i removed the actuator from my 94 parts rigs and was in the process of installing this when i noticed the gears are noticeably longer on the 94 than what was on the 97 model. Part number is the same on both and it shows good for all years of 80 but don't know if I need to change out gears or if it will work as is. Also are there any other differences between years?
Thanks
Can you swap them?
Well that's why yours won't work, you've plumb worn the end off!
Seriously, look at the hub length. It appears to be the same. If it is, and you can install the actuator, you should be fine.
For some reason, they decided to relieve the front of the gear face. Maybe they figured the worm engagement was only point contact, so they were wasting money on the longer face length. Check the engagement/clearance beyond the worm.
I am just assuming you can. There is a C clip on the end and you have to pull the gears to get inside the actuator to clean and recondition. I'm just trying to see if there is a reason to.
Well that's why yours won't work, you've plumb worn the ends off!
I am assuming you forgot the :) so we would know your humor
That was implied ;)
Curious if @landtank has seen the different sized gears from early to late model
