Front grease for knuckle??
Fort Worth TX. Need a ADDRESS??
I was going to pull the plug out the top of the knuckle to pump it with grease but the owners manual says to use a funky yota grease. What grease do you guys use and do you recommend filling them with grease?
Ditto on the palladium easiest grease with 3% moly to get ahold of.
Are the knuckle seals leaking? Are the seals between the diff and the knuckle leaking (heavy goop when you drain the diffs)?
If the answer is yes, then do the front knuckle rebuild. If the answer is no, then there is little need to add grease through the fill plug. Take it apart and repack it with fresh grease if that is what you want to accomplish.
