Front drive shaft alignment marks?
Beech Bluff, Tennessee
Since I've had my Cruiser it's had a little vibration in my front drive shaft, so I'm finally going to replace the u-joints. It appears one has been replaced before since it is non-greasable. I know two piece shafts usually have alignment marks to ensure proper balance when put back together. I'm wondering if it was put back together correctly when the joint was replaced. I have not yet pulled it out and cleaned off the grime to see. My question is where are the alignment marks on the shaft?
IIRC there are none? The best way is shaft in a vice, then lay a rule across the joint at each end and then look for the rulers to be level. Before doing any of that, I would check there is no vibe once you get the shaft off (CDL), before you start chasing your tail.
Some vehicles have a thicker spline to prevent misalignment during assembly, worth a look before pulling apart?
regards
Dave
Mine had bold white lines - like those from a paint marker. However, the shop made new lines when they balanced the driveshaft after installing the new u-joints.
Makees one wonder if the shop that replaced the join put the shaft back together in phase or out of phase. Many of these came from the factory out of phase which is non standard for the industry, but they worked well that way. If they changed the phase, that could increase vibration problems. search for Drive Shaft Phase on this forum for lots of discussion.
I got the new U-joints installed this afternoon. I drove it without the front drive shaft and she was smooth as silk. I made sure driveshaft was in phase when put it back in. Still have a little vibration, though not as bad as it was.
Try it "out of phase" to see which way is smoother. Many of our trucks were built OUT.
Got tired of waiting found my OME 3" heaves on eBay they were at my front door 2 days later.
I forget the exact spec, but I seem to remember something about the alignment is based on the zerk fittings for greasing the joints. I do not remember if the Original condition is in phase or slightly out of phase or completely opposite phase.
