Front diff lock question.
Darwin, Northern Territory, Australia
Were coming into some money shortly and the minister of war has said we can purchase a front diff lock.
I own a part time4wd 80 series and need to know if the auto lockers are any chop compared to a much more expensive air locker?
I realise all the differences but need some real time experiences.
IMO do it right the first time with a selectable locker. There are driving (on and off trail) conditions where, especially on the front, you do not want both wheels locked.
Agree 1000, yes 1000, percent! You do not want an auto locker on the front except for a trail only rig. JMHO, but, you asked! Either get ARB's or retrofit the factory lockers if you want. HTH. :cheers:
Did you say "part time 4wd" ? I didn't know this is an option. I have often wondered if my LX450 would use a lot less gas in 2 wd than 4wd. You know if anyone has done any work to make a full time 4wd into a selectable 2wd for those city miles ?
You can make the FZJ80's part time 4wd. My brother Mark is going to be doing it soon to his 94 since he is mainly using it to tow his rock crawler and it saves aprox 2-3mpg is what I'm told.
You have to get a kit from Slee that eliminates the center diff (no more viscous AWD though) and the front hubs from a Toyota mini truck (79-85) as well as a center diff lock switch from a 91-92 FJ80 so you can unlock the center diff. All together you'll prob spend about $550-650 in parts.
The only reason I'm not going to do it to my 94 FJ is because I don't have much faith in the selectable front hubs to handle the abuse I plan to throw at them. But if you do mild to moderate wheeling then you should be fine.
Looks like an auto locker then.
ARB to match the rear.
Uhhh, maybe you meant the reverse, an ARB is not an auto apparatus it is selectable. :cheers:
I wouldn't sweat a automatic locker in the front on a part time truck.
This is what I run in my FJ40, with an ARB in the rear.
ARB's require so much to be correct for them to operate that sometimes the headache-less auto lockers are nice.
It does make it more difficult to turn the rig when in 4wd. I just shift out of 4wd on easy sections of trail. (in coast the auto locker unlocks, so you don't have to unlock the hubs as well).
I would not worry about exploding a set of Aisin hubs (the oem hubs from any 79-90 land cruiser and 79-85 toyota truck/4runner. I don't care how hard you wheel. They are all steel unlike most aftermarket hubs and very stout.
Yes you are correct ,I made a blunder there.
CruisinGA ARE they ok out in the bush?
I mainly drive sloppy mud or very dry dusty terrain up here.
I have power steering so does that help?
Would it over stress the steering box?
I'm still leaning towards the ARB so all arguments towards the auto will be closely read.
I'm a fan of selectable lockers personally but in the past two years I've fitted about a dozen 4WD Systems Lock Rights to various club mates GQ Nissan Patrols. They all swear by them but then again none of them have driven with air lockers much to have something to compare them with. For the price though they are good value.
If you've already got a rear airlocker I'd go for the ARB for the front as well. They offer the advantage (as I'm sure you already know) of being able to be switched off which is a huge advantage in slippery off camber situations. The mates of mine with their auto lockers often come unstuck in these situations whereas I (unlocked) usually can make it.
Watch some of the winch challenge and outback challenge DVDs. The navis are usually screaming out "locker in....locker out....locker in.....locker out". Some situations require a locker some don't, airlockers let you decide instead of forcing you into a situation you might not want to be in.
Mickldo said:
y know)Watch some of the winch challenge and outback challenge DVDs. The navis are usually screaming out "locker in....locker out....locker in.....locker out". Some situations require a locker some don't, airlockers let you decide instead of forcing you into a situation you might not want to be in.
I keep magazines in the center console for my passengers to read while I'm engaging the factory lockers. My original plan was to find a clean, bargain 80 without lockers and then put in the ARBs. It's up to you to decide what the premium is worth, but I might suggest that it is not limited to the installation price for ARBs since an ARBed FZJ80 would be worth more, at least to me, than one with the factory setup.
I think Auto locker is slightly different than Aussie type locker. Aussie locker is always locked except when turning. But if the torque is there then it will not unlock. Auto locker, such as Detroit locks based on the torque (I think). So it is may be unlocked most of the time (regular driving condition). Also, if an inner shaft is broken with an auto locker, it might break the locker as well whereas an Aussie type locker will be OK.Now, for a part time 4WD I don't see why you shouldn't be fine with an Aussie/lock rite up front but as mentioned above, there are certain driving conditions where you don't want front wheels locked regardless on/off road. ARB will give you the choice to stay unlocked in those condtions. So, ARB most certainly is the right choice. Yes it requires a bit more work to install and maintain but it's worth ;). It locks and unlocks FAST.
You're not quite spot on here...
ALL auto lockers (EZ, Aussie, Detroit) only unlock when there is no forward torque applied through the front driveshaft, so either coasting or with the transfer case in neutral.
It just so happens that most of the time, when turning, you are not on the throttle, so because of the coast condition, ANY auto locker unlocks. If you apply throttle through a turn, the locker will be "locked up"
I own an EZ locker, an ARB and two factory lockers. Sure the ARB is the bling, but I, and my buddies have been in situations where the required air supply to operate the ARB has been an issue. (failed air compressors, broken air lines etc). If you carry spares and have a backup air source, it is no issue. Just most people do not. I am just pointing out that while the selectability of the ARB is key in some situations, the complexity of the system can be its downfall. The auto locker is always there, there is nothing to think about.
[/quote]I would not worry about exploding a set of Aisin hubs (the oem hubs from any 79-90 land cruiser and 79-85 toyota truck/4runner. I don't care how hard you wheel. They are all steel unlike most aftermarket hubs and very stout.[/quote]
Those hubs are very tough (much stronger than aftermarket) but I still managed to blow a OEM Toyota hub on my last rig and it weighed about 1500lb less than my 80. But maybe I am one of the rare few that has broken one, I dunno?
Do you like to steer in the mud? if your front is locked it will only want to go straight forward. Same for snow which is a major reason I will only go selectable in front.
anyone who has ever tried to steer an 80 with a locked front will tell you it's a ROYAL PITA. I don't know what it is about 80's but they do NOT want to turn when locked. Hard on the PS? personally, I would assume so.
I know my pump died and it was big $$$$ for a new one (the rebuild kit lasted 5 hours before failing)
Sounds like you have ARB in the rear already? If so it wouldn't make much sense to put something else up front IMO. Go ARB
My opinion is that a full time spool or auto-locker in the front is rarely the way to go in any vehicle, even if it's a trail only rig.
The rear is usally OK with a spool or locker but up front almost anyone with much off-road experience will tell you that you need something selectable up front. There are just too many times you need more steering control than a spool or unselectable locker can provide. I like the idea of a limited slip/ selectable locker since it gives the best of both worlds on and off road.
Thanks for all the well written replies.
I've decided on the ARB .
Mainly to match the rear, they seem unbreakable to me.
Ahhhh... excellent choice kimosabe!
