Front Diff Cover: Gasket or Nah
Idaho Savage
GOLD Star
Idaho
Seems to be different opinions on here. Long story short, got my gears redone (yay) but the front diff cover is lightly leaking. I’d take it back to the shop but they’re 1.5 hours away and I’ve done this on other rigs before….easy peasy.
So…need to remove and reseal. Do I need a gasket or will a thorough cleaning and black permatex do the trick?
Thanks
I used the red/orange FIPG when I just replaced my front third member. There's not a removable diff cover on the 80 series front axle though, the whole diff needs to be removed to reseal if it's leaking.
Any pictures?
FIPG all the way, no gasket needed. Toyota spec for those covers is the Loctite 518 or the Toyota FIPG equivalent — that's what the FSM calls for and it's what I've used every time. The orange Permatex (Hondabond or similar anaerobic flange sealant) is also fine. Black RTV is what I'd avoid; it doesn't like being exposed to gear oil long term and tends to weep eventually.
The one thing that makes or breaks it is surface prep. Both mating surfaces need to be clean metal — zero old gasket material, zero oil film, zero grease. I use a razor blade to get the bulk off and then wipe everything down with brake cleaner and a lint-free rag. Don't skip the brake cleaner step, even if it looks clean. Oil contamination will compromise the seal.
Apply a thin, consistent bead — about 2-3mm, running just inside the bolt holes, not outside them. Seat it and run the bolts finger tight, then let it tack up for 10-15 minutes before torqueing. That waiting step matters because FIPG needs slight compression as it starts to cure to seal correctly. Torque in the correct pattern, fill the diff, and don't be tempted to drive it for a few hours.
Done it this way probably a dozen times on various 4WDs and never had one come back.
I've used a paper gasket with no sealant. Works fine, easy peasy and is reuseable too.
There is no pressure or great heat here. Proper bolt tightening sequence is important.
I will say the last time I tried RTV I couldn't get it to seal until I finally removed the axle housing and set the diff vertically. Once I did that it sealed great first try. It's just tough to mount the diff under the rig without accidentally messing up the bead
"Toyota spec for those covers is the Loctite 518 or the Toyota FIPG equivalent"
Are you talking about the FZJ80 or other Toyota vehicles?
Already mentioned, the 80 Series does not have diff covers, the entire Differential (Carrier) Assembly comes out of the axle housing
Basically the Factory Service Manual (FSM) method when installing the Differential Carrier Assembly is that you first clean the contact surfaces (Carrier and and Axle housing) then Install the differential carrier assy and the gasket with the 10 nuts and washers ie: dry, no sealant, no gasket dressing (check FSM for torque specs, RM451U, download from the RESOURCES section above).
Many people prefer using FIPG but the paper gasket by itself (no RTV) is the FSM method.
FWIW
