Front Courtesy Lamp
Orlando, Florida
My front courtesy lamp doesn't come on when I open the door. The rear one does come on so I know its not the door switch. Strangely the lamp will work if I turn it on manually with the switch next to the lamp so o know its not the bulb.
So if its not the switch or the bulb what is it? This one has me scratching my head[emoji51]
Sent from my SM-G920T
Each light has a switch. The middle and rear have the 3 positions (on/off/door) the front only has an on/off. I can turn the front one on with the front switch and it works but when it's in the off position it is not triggered by the door. Now I suppose this could be by design but it just doesn't make sense given that the one place you would want courtesy light 100% of the time would be the front.
The middle and rear work fine in the door position.
Then it is working correctly. The front light is turned off and on by the switch only.
I had a feeling that was going to be the outcome although it never entered my head as a possibility until Kliars and you suggested it. It's so dak in the cabin that the kids struggle to put on their seatbelts. Might have to investigate brighter bulbs or something.
Thanks again for the help.
I always though the courtesy lights were in the ones at the bottom of the doors?
Just bought a couple of Philips LED lights to swap out the existing incandescent 10w jobs to see if they made a difference to the quantity of light but neither of them light up at all. Not sure if I have failed bulbs or if they just aren't compatible.
You probably just have them in backwards. Flip them around and that should get them lighting up. I had the same problem with some LEDs I purchased at the autoparts store. They only work one way unlike the original filament bulbs.
Your the man. Swapped them and they work a treat. [emoji3]
If you run a jumper from the middle row light to the map light they will both come on when the front door is open.
But beware that if you install the "elcheepo LEDs" in the map light it will be almost blinding. I disconnected my jumper to the map lights after installing the LEDs.
