Front bucket seat adjustment spring cable 75 fj40. Have one? Make one?
Phoenix, AZ and OC, CA
Does anyone have one of these laying around? It is the little cable spring that goes between the two seat rails. I can't adjust the seat without it and the part went missing during my restoration. Failing that can I just make one? Anyone have dimensions? Anyone DIY it?
It's not a spring.
It's a piece of steel wire, with bends on the end that are kept closed with a keeper spring. I lost one of the keepers, so I used a washer instead.
The lever arm unlocks the driver side rail lock, and the wire disengages the passenger side rail lock. No advanced technology involved.
I think you dropped a zero. 0.030" is a common dimension for flux core MIG wire.
its also a common size for er70...flux core is brittle and cant be bent.
so i looked and i have the oe wire hanging on the wall and mig wire in place.....irrc the oe wire needs installed before the brackets are fastened to the seat frame, and i missed that and decided it wasn't worth the effort to disassemble just for a wire that would be used once, maybe twice a year at best...that was 8 years ago now....should it fail anytime soon, ill replace it with some 0.035 er308.
