Front axle tire wobble
Ramona, California
My father and I started working on the FJ and we got the fuel lines connected to the OEM poly tank. I sat atop the tire to tighten the fuel line to the carb and the tire started to moved so I thought it was loose so tightened the lug nuts, then I moved the tire again and it still wobbled so we took off the tire completely and my dad said that it was missing a piece of metal that kept the nut onto the axle. Does anyone know where to get this piece? Or if there is anther problem?
Sounds like the bearings were loose. Your dad may have been referring to #4 in the SOR pic. This is a type of lock washer that keeps the bearing retainer nut from coming loose.
