Pretty similar. Couple things to watch for:
If you have factory e-lockers, make sure to lock the differential before pulling axle shafts.
Birfields come in different lengths between early and later years. If you are replacing them, make sure to get the correct shaft for your application.
There is an axle shaft guide inside the axle housing. It is possible to knock that guide loose when inserting axle shafts.
I would increase the pre-load on the axle bearings above FSM recomendation. They tend to loosen up especially with larger tires.
Otherwise, dig in.
