Front Axle Q - Grease
Minnesota
Another rookie Q:
I used Mobil 1 synthetic grease for the inner/outer hub bearings. I read the front axle rebuild and Romer also used it on the hub bearings and on the upper/lower trunion bearings - which I was also thinking of doing. How does this not get into the birfield area? I was planning on using a moly fortified grease for the birfields. It just seems like the two would get all mixed together. Do I use the same moly grease for the trunion bearings as used for the birfields?
Thanks
I used Amsoil moly-fortified synthetic grease for the Birfield and trunion bearings. The trunion bearings are a low speed, high pressure application so the moly fortified should work well there. (I know the FSM calls for moly-fortified on the trunion bearings in my '85 4Runner. I just assumed it was the same for the 80 but I didn't actually check.) I also used Mobil 1 synthetic (red) for the wheel bearings.
To be honest though, I don't think it would really matter that much if you used the non-moly for the trunion bearings. Of course you would get a bit of mixing but I doubt that it would hurt anything in the long run. I think using synthetic for both is a great idea btw.
I based my decision on whether or not to use synthetics on how long I wanted to stay out of the area.
On my wife's DD soccer mom grocery getter I used synthetics throughout the front end. I don't want to have to open that up again for 10 years if I can avoid it. I put ~$100 in grease in that truck.
On my trail/winter DD/play truck, I went dino greases with the idea that I would have it open again in around 2-3 years when I wear out my existing 33" tires and go to 35" tires and re-gear. After changing out a leaking inner seal two weeks ago and repacking, etc... this kind of paid off. It only has $30 in grease in the front end, so its a lot less painful to toss out the birf soup and start over on it.
If you plan to have it open every few years anyway, I don't see any harm in using non-synthetic greases.
IMHO, YMMV
I used Mobil 1 in my last rebuild for research purposes. I had it apart twice now to see how things are going so far so good.
