Front Axle Lamentations
Guys,
My wallet is really starting to hurt. I have a '96 FZJ80 with 184K. I changed the front inner axle seals myself at about 90k which is about what to expect. Then again at about 150k, I had an independent shop do the job. I guess that isn't too out of line, though I would have hoped for a longer interval. At around 165k, I started seeing the telltale seepage at the knuckles. I was somewhat dumbfounded, and also realized that those guys wouldn't own up to doing the job wrong....anyway, I took the truck to a highly-recommended Toyota mechanic at a dealership local to me. This guy definitely knows what's up. He is a 100 series owner and from my conversations with him, I know he did the job right.
So here I am at 184k with an axle that needs the job yet again. I see the gear oil seeping out of the knuckles, and confirmed by finding the differential overfull, foaming and obviously contiminated with grease. What is going on? Is it possible that there is an alignment issue such that the knuckle isn't centered with the axle housing? I'm guessing that the seal is wearing quickly because the shaft is running out of center in it?
HELP! and Thanks
PS I don't have a place to do this messy job myself anymore or I would. I live in the SF Bay area, btw.
Very hard to know what the issue is. Assuming the seal was replaced correctly, the only thing I can think, is that the seal surface on the inner axle is worn out. They get grooved from years of running within the seal, especially if the job was neglected and the axle ran on the spring, after wearing through the seal itself.
You need to pull it apart yourself and have a disinterested look. I don't know if there is a speedy sleeve for this application.
On other thing to consider is that the spindle bushing is worn, allowing eccentric movement of the inner axle and premature wear on the seal.
Good luck with this, but there is no substitute for doing this yourself.
I'd bet $100 that the independent shop replaced the seals that were leaking in their eyes like happens to 80 owners nationwide routinely. That means the outer knuckle seals - the triple seal. But they didn't replace the source of the leak - the inner axle seal. From what I know, this seal is NOT included in a front axle seal kit and for this reason independents often have no clue about it. This exact thing happened to my bro in law - exact. I'm sure it has happened to forum members as well.
I suspect that when you get it back from the Toyota dealer-which you will now call to confirm BEFORE the work-the inner axle seal will have been properly replaced and you'll get the normal interval of leak free service. You should also look at the FAQs here and modify the front axle breather for extended seal life.
DougM
Either you have a groove worn in the inner axle where the seal rides, or the brass bushings in the spindles are worn out. My bet is on the brass bushings. They can be replaced, but they are a PITA to get out of the spindle.
Doug,
I did extend the front diff breather just after I had the job done by the Toyota mechanic. I will investigate this further with the clues and ideas that you guys have given me. Thank you!
PS
I brought the parts to the independent shop myself, including those inner seals because I knew what the problem was. I also brought them my FSM to use in the process....
The seals worked correctly with new parts for 90k. Now they don't work. Look for a worn part, such as the ones that have been suggested- spindle bushing and the contact point between the seal and the moving parts.
-Spike
