front axle clunk sound?
Rio Rancho, NM
I'm in the middle of knuckle rebuild. What started my job was a clunk sound in front DS axle/hub and no idea when it was done anyway. What I found after tearing apart but before I removed spindle is some play in axle that causes metal clunking sound. I could literally lift axle up and down maybe 1/4 inch. Is this normal ? Sounds to me like the source of my clunk but not sure what cause is. Birf was not soupy no mix. Was light on moly I beleive though. Timken bearings inside(not factory so done before)were all good I think.
Your driveline should have a little play.
Have you checked your hub flanges?
Once the drive flange and spindle have been removed there is really nothing supporting the outer end of your axle. So yes it's going to be free to move a little.
I'd think it's much more likely that your clunk noise is do to a worn component in your steering or suspension. Like a bad bushing. Or simply a spring moving around when fully flexed. But you did not offer any description of the sound or when it happens?
The hub flange is the little dude you removed that was held on with the cone washers. The birf splines into and turns your hub when your axle turns.
They eventually wear out and need replacing.
Feel free to use search/FAQ for unfamiliar terms.
If you swapped up to bigger tires a little extra bearing preload is a cure I did when I went to 35's on big black.
It starts clunking a little on potholes, then whichever side it is when you turn the opposite direction.
At least if you get it while rolling, like mentioned if you change torque on flats it's prob in the driveline arena.
I suggest as your avatar looks like you 'done tinkered' a bit from factory loadout.
Also check the bronze bush in the rear of the bearing spindle, can cause noise and false trigger the ABS.
Options to replace are solid or later roller/needle bearing.
regards
Dave
I think you are spot on here as the ABS starting to act up at same time as clunk started.
It's a pothole or small bump type when clunk happens. Not wheeling and have never wheeled this rig yet other then hunting.
No lift, just 285s and they have been on 3k miles.
How does a guy know if this bushing is worn or is it more likely just slop preload or bad wheel bearing (all look good to me but as mentioned was light on grease
The classic is braking towards a junction and running over a raised drain or hitting a pothole, the brake pedal judders as the ABS triggers.
Any wear on the spindle bush is quite evident, there is a picture on the thread I run, look at post #48, My LC 80 thread. Copy and paste the picture to your desktop, then zoom in and check it out.
regards
Dave
Ok I did knuckle rebuild, still made the clunk. Ordered replacement spindle bushings added a little more moly and pounded in new bushings. Went for drive in hi and 4low up sand hills. Still makes clunk sound so short of axle issues it must be in suspension...4low and high drives fine and makes the sound in both when flexing on bumps. Also ABS is still tripping but not as bad.
My wheel bearings and seals were just as I set them last week and I made a 400 mile trip since then.
Any more recomendations?
Jeremy56, just an idea, but check for any play in your pinion bearings on your front axle. While your at it, take a look at your front drive shaft U joints too.
I have not checked these items is there a recomend approach? I have done very little offroading in this rig(so far). I will put it back on stands this evening and go through it
Fwiw, I tried to pull an abs code and got rapid blinking continuous, so no codes stored in that.
Update: replaced suspension with Dobinsons tapered 2.5. I had broken front springs in the top where they sit next to metal. Also while I was messing around adjusting everything I noticed I had a lot of play in tie rod and drag link. Ordered new HD trail gear tie rod kit and drag link ends as well as steering damper. TBD but im almost positive the sound was tie rods and I will need an alignment anyway so they are in the mail.
Does anyone know if bad tie rods would trigger ABS light or occasional pulsing?
Bad tie rods will NOT cause ABS light or occasional pulsing, but loose wheel bearings would.
no, but grease on your abs sensors will, pull them and clean them off. if it still activates there's a little fuse under the hood says ABS, pull it and don't put it back in, see if that helps...
That doesn't make sense considering the ABS sensor is mounted inside the only cavity on the whole truck that contains grease and it's supposed to be be near full and get slung around inside there.
