Front 3 Link?
Has anyone taken out the front bolts on the control arms and ran an upper control arm on the top of the diff for a 3link? It seems like a cheap way to 3 link the front and get away from all the pinion angle problems people have from lifting their rigs? Does the elocker diff from the newer fzj80's work in the ealier fj80 housings?
Has anyone taken out the front bolts on the control arms and ran an upper control arm on the top of the diff for a 3link? It seems like a cheap way to 3 link the front and get away from all the pinion angle problems people have from lifting their rigs?.....
Seems like this has been done - search would help you here.
.......Does the elocker diff from the newer fzj80's work in the ealier fj80 housings?
This is a big no. You need elocker housing to run elockers, which were only available on FZJs. You can swap in housings, but you'd also need the harnesses and electronics to run them. I believe that's also been done, so search would be your friend here, too.
Has anyone taken out the front bolts on the control arms and ran an upper control arm on the top of the diff for a 3link? It seems like a cheap way to 3 link the front and get away from all the pinion angle problems people have from lifting their rigs? ...
Would work on a stock height rig with short shocks, won't work on a lifted, long travel rig, the tie-rod is in the way. Don't see how this would change the pinion angle, if the caster is corrected, the pinion will be at the same angle regardless of correction method.
What would the hight of the 80 have to do with this setup working or not? The stock control arms are plenty long to work as lower control arms, probally long enough to max out 16" shocks and are'nt in the way of the tie rod. I serched 3 link and didn't find anything on this setup and don't have the time to read through every post the find exact answers. Just looking for a way to cheaply get away from radius arms which don't move worth a s*** unless you unbolt one of the mounts. I was just wonderin if anyone has done it with good results before I jump in on it?
ActionJackson left his tie rod in the rear, and his lowers looked every bit as close as the stockers. Any input on interference issues with his setup? Nevermind that; looks like he went over the top of the tie-rod. Does that change everything.
You will get a lot more rotational axle movement with the 3 link, which will bring the tierod into contact with the control arms - radius arms prevent this (and have the associated bind in the 80 series design).
I'd move the entire steering up front with a heim based crossover setup if I really wanted to do a proper 3-link, and I'd also go to a mid-length arm design (about 22" lower arms) mounted at axle tube height.
Tools (posted earlier in this thread) has a pretty slick setup keeping the basic stock stuff (custom arms), you should check that out.
