Fridge Console Q?
Sacramento, CA
Don't the non-US issue 80 series landcruiser's have a center console that can also act as a fridge? If they do, is it possible to get one sent here to the US? Just wondering if anybody knows anything about this. Thanks for the help! Eric.
MOT could probably source you one, expect to spend big bucks, and probably need to run new refrigerant lines, etc...
Easier to buy an ARB or Engel
Eric,
As Ben stated it's a big bucks.
If it were just the console and you didn't need the piping, etc... then it might not be too bad, but as MoGas said, it would make much more sense to go with ARB or Engel since they would end up being cheaper, more space and more versatile.
Mot :)
Eric,
Mot :)
cool, that's what I figured was going to be said, but I wanted to make sure that it wouldn't really be worth it. Thanks for the help!
Do you mean the console between the two front seats, which has three buttons for it to be off, cool or ice? I have that, but I store stuff in it and have never used it as fridge.
Why would it be big bucks, and what piping do you mean? It seems to me it's just a plastic box, not even that well insulated, with a small refrigerating unit plugged into the side... am I missing something?
It is expensive here because it is not available in North America, has to be sourced from overseas, and is cooled by the AC refrigerant which has to be plumbed in with the appropriate piping, and charged, etc. AFAIK, the refrigerant system is run off the vehicle AC compressor and is not a stand alone refrigerant unit.
Do we know for a fact that it plumbs into the vehicle AC as a second evaporator, or are we assuming it? It would be a much better box if it had it's own motor/compressor and did not require the truck to be running.
Maybe Prossett could find out for us if he ever has reason to look at it closely. It either has a pair of refrigerant lines coming out of it or it doesn't. Those lines may trunk into the rear air in his case, so finding the lines may be tricky.
An easier way to check may be to just turn it on while the vehicle is off, listen to see if you can hear a compressor/fan giong and see if it gets cold. If it does get cold... Hmm...
Mot, has spoken, and he definitely knows. :) Maybe he can clarify. You may also find info on a search as I think it has been discussed before.
Ice / Coolbox
We know for a definite fact that it is connected to the vehicle AC because when the AC stops working after the refridgerant has all leaked out the fridge stops as well.
Careful examination will also reveal that it has little ice cube trays behind the plastic cover inside the box at the front and when working correctly will make ice in them.
The pipes run under the vehicle and head up to the front of the vehicle.
Cheers
I went on toyota techdoc europe to look at this and the sub tank set up for an 80. They didn't go back to the 80 series so I had to settle for looking trough a manual for the FZJ100. And it does appear there are 2 lines that come into this unit from below.
Not only do they get the cool box but the winch and the subtank.
I down loaded the repair manual pages for the cool box. It has a nice exploded view. Mind you its for the FZJ100.
If someone can post it or tell me how to convert a pdf to a jpeg I will post it.
BTW techdoc europe also has an online EPC. I tried to scrouge up a VIN from ebay UK but they don't list them. I tried one from Australia and mine but both came back invalid.
The console fridge was offered in the 1st gen Toyota Van (vanwagon?) for the US market. It is plumbed to the AC freon system. No running engine=no AC=no cooling in the console.
Oh, this only shows the box itself but you can definately see 2 lines coming into the until from below.
If you want to spend 5 bucks you can go to the techdoc europe site and pay for a 2 hour subscription and research it more.
http://techdoc.toyota-europe.com/
and the owner's manual (which I just got) states that "using the cool box will lower air conditioning efficiency, especially in the ice mode"
Thanks for the 2 pdf files showing the factory fitted coolbox
I have a 1991 Sahara VX turbo diesel with Moon Roof and was thinking of pulling the coolbox out to give me more room for radios etc
Trying to fit more radios into the dash is a nightmare
