Fresh Pull cable slipping
I didn’t find a thread on this. Perhaps because the fix is simple.
Just installed the heater and blower. The spring clip that holds the blower fresh air door cable was slipping. Perhaps I installed it wrong:meh:
Here’s the fix I came up with:
Position cable with door closed and place zip tie
Wrap zip tie with tape so it can’t slide on the cable sheath
Is dry graphite the best option for this? I'm having a hard time getting mine to open and shut like it should.
I like the zip tie idea bigredrocker. That's the definition of "cheap insurance"!
I've had good luck with this product for lubricating shifter / brake cables on bikes. Would work great for this application, too.
What year is this? My 68 and 70 FJ40s have a clamp that tightens at the damper. For this type of cable I always pull it completely out so it's straight and use white grease. Work the cable in the housing until it moves smooth and easy. Most the sprays I've tried only last short term.
Did you try lubing the cable as well?
I did not oil the the cable. I had to relocate the fresh pull cable in a less that optimum location. It takes a harder bend than the factory location. You are likely correct oil may have resolved the issue. I need remove the fresh pull and warm pull cables at some point to spray body color on the steel mount plate I fabbed up. I’ll follow your advice to oil’er. I think I’ll leave the “zip stop” cause the cable ain’t goin’ nowhere with that on. :cheers:
