Build Freeborn In The USA Build
Got the bezel and painted and a rear step
Mine has rust in all the same places, I was hoping for better when I took the the corner protectors off.
What happened to the 15'' tires that were on it? I'm looking for some used ones, something temporary while I work on mine.
I'm in Northern NM
The spare that was on it was original to the truck and didn't hold air. 2 of the other 4 didn't hold air and we kept one of the 4 to use as our spare. You might go to a tire store and see if you can bum a set of used tires. If they are very used tires I bet they will give them to you. Where in NM are you? We'll have to get together for some green chile once we have them on the road.
Count me in, for the green chilies not the old tires.
I’ll be back up at my place for a spell in a few weeks (near Angel Fire).
Ian
The local tire stores are telling me used 15's are getting harder to come by but I'm sure that some will pop up sooner or later. When my rig is road worthy a get together would be fun. I live just outside of Taos.
Put the top on today and went out driving. We just finished painting and restoring the top and drip rails to match the bezel.
It’s still idling too high. Feels like it going to run away. Need to dig into that. Also got some more parts to install.
New CR weatherstripping
New exhaust/intake manifold gaskets
New HFS extended rear shackles to correct the saggy bottom
New CCOT rock guards for the tail lights
New and used Bilstein shocks
We’ll see how far that gets us. It looks awesome and is fun to drive.
Added the HFS lift shackles. They are 1.5” longer. Also added urethane bushings all the way around with Bilsteins. The difference was incredible. It’s a totally different truck.
The first pic is a square on before shot so you can see the change in stance.
Great progress. Have enjoyed following along.
Curious - do you plan to eventually replace the springs?
Yes probably put an OME lift on at some point but there’s a ton of other things before we get there. I think he wants to do the body and paint, re do the seats, and maybe a Sniper conversion first.
Got some work done this week on the intake and exhaust manifolds. Trying to track down the intake leak(s) so we can get this thing to run and idle better. How do those gaskets look? Can you see if or where it was leaking? A couple of the studs were loose.
We sealed up the heat riser mechanism. I have all new OE gaskets. Heat riser delete kit. All new OE studs and bolts. Picked up new downpipe and EGR stud kit from vintageTEQ. Also new fuel cut off solenoid from the same place. Great stuff from @ToyotaMatt. Next step is to get it all put back together and tuned up then for new exhaust.
this is a recent TECH. Video ,,.,,
in a perfect world this will be the A+ Scenario :D
Here it is mostly put back together. Hopefully we’ll have it back to running this week? New manifold gasket, new fuel shutoff solenoid, new studs everywhere, new paint everywhere, and carb insulator. This should eliminate all the vacuum leaks so hopefully we can tune the idle. Once that’s done it’ll be off to the exhaust shop. I wonder if it’ll be as fun to drive without all the gas and exhaust fumes?
Put my dad‘s wheels and tires on to see how 33 will fit. Little that I knew I would tear the boot on the steering knuckle, rookie, mistake, huh. then I put in all new tie rods. It’s on my bucket list not just because I tore the boot. then I was hooked so I got me a pair of 33s 1050s and I put them on my wheel.
