frankenmotor
san diego
HELP! I had someone build a f bottom and 3fe top end and it didn;t work out! I have in now at the machine shop and big question came up today, Which push rods do you use? the ones for the long block or the ones that match the head? Thanks in advance!
The ones that match the block. I'm assuming you are talking 2F bottom end and 3FE top end..... If actually an F block.... better hope its the latest version that suppies oil to the head through the deck surface rather than one that requires an oil line to the rocker assembly... and did the F/2F have flat top pistons to match the closed chamber 3FE head?
It is a 2f block and 3fe head. The builder says to use the 3fe push rods and that no oil cooler is needed. I am in a quandary. I am not having the original builder do the “repairs” as I do not trust his work in hindsight. Thanks. Anyone else built one of these that they are using? Thanks
Search for threads in all 3 forums (40/55, 60 and 80) with 2FE in the title. Yes, many on the forum have made them, including a couple at least in 91/92 FJ80s. I have one in a FJ62 and one in a FJ55.
You can use the search engine on the forum, but using google with the search "2FE site:ih8mud.com" might be more user friendly for you.
