Fox 2.0 failure
@Flank where did you buy your 2.0s? Just curious
Fox recommends 10k IIRC
Just read it's 10K for 50/50 street/offroad or 50K for 100% street use. 10K is ridiculous & unacceptable.
My instructions are at home but I thought I remember the 10k being for offroad use. Onroad was 40-50k I think.. Obviously for our roadtrips the real answer would be somewhere in the middle.
Either way, I have to send it off. If I do, it'll be to fox.
Still even at 25k miles of mixed use, that's every other year to rebuild 4 shocks. I may reconsider these IPFs though I don't do any serious offroading compared to some here.
Shock rebuilding is not rocket science.
I personally have used Fox, and many other companies who specialize in rebuildable shocks.
My findings are that the small no name guy does a far better job!
My 02...
Just out of curiosity, what's the average cost and turnaround time to replace the oil/seals in these guys? Seems like a lot of effort for the average Joe.
$50 per shock. Ouch! Each ~25K it's $200. REALLY rethinking getting these now.
http://www.ridefox.com/service.php?m=offroad
It's funny how perspectives are so different from person to person. I looked on their site and though, wow, only $50 each to rebuild at the factory. Seems a lot cheaper than having to replace shocks every 50-60K, I like re-usable products. It helps that their maintenance facility is within walking distance of my place of work.
I agree and re-usable is great, and often better quality. The rest of us not your place would be looking at the rebuild fees, and hope for a ATV/bike shop with quick (and correctly done) turnaround while the truck is laid up...or a temp set of shocks which is pointless in the rebuild ideal...or a beater Honda. Still need to research local options for rebuild though.
99% sure the seal failed because a rock scored the shaft. Not Fox's fault at all. I learned the hard way too. Shock boots are mandatory, at least on the front. Luckily I was 40 miles away from Down South when it happened and Sunny rebuilt the shock for free while I waited in the parking lot. Awesome customer service.
The 2.0 Resi's lasted all the way down to Ecuador and I'm still wheeling them without out issue 45k miles later.
The smallest imperceptable nick will destroy that seal. They really should come with $10 boots.
After riding a few hundred miles with @Qball over asphalt, washboard, rocks, boulders and dirt I can absolutely say I love the Fox 2.0s and would not not hesitate to replace my OMEs with these. If the resi's are only $250 then I'd be swayed to go that route. But what QBall has now, honestly, had a far better road feel and off road feel compared to the far more expensive King Shocks that another mudder on that same trip was running.
Maybe because some of those mudders with King Shocks are far too lazy to adjust their shocks for pavement and off-road :flipoff2:
If you are referring to John's, his valving is a bit firmer than mine, he also put them on the hardest setting and he has competition springs so it's going to ride a bit rough. My kings 2.5 remote res is awesome on the trails, I enjoy watching other cruisers bounce up and down when they hit obstacles. :cheers:
Have any input on pro/con of a boot vs these: http://www.sportsmobilestore.com/fox-shox-roost-guard/
I know you can only fit these to the rear on our trucks.. but that location actually seems to be more in the line-of-fire of rocks than the fronts..
One other factor, is that in the instructions, the directive was to install piston down, body up. I'm wondering if reversing this would perhaps have an impact? I'll also ask their recommendation on using a boot. If a "common" failure point for a $130 shock is that a piece of grit on the shaft can cause a total failure, then that is a problem. I thought I'd try these over OME sports, which I have not heard failure stories about. The OMEs on the rear of my truck are obviously fine.
I was scratching my head based on Flank comment above, looks like the shocks are installed backwards?
How so? I had mulled over whether the shock body should be top or bottom, and after combing the instructions, found a line that said they should be on top. I asked Fox, and they had no definitive on it. By the nature of these particular shocks, you can do either.
