so which is it? also what years did they comme from. looked in the tech links and had no luck. oh, and by the way thx. jim![]()
The only difference between the F250 towers and the F350 towers is the # of mounting holes. The length is the same. F250 has two predrilled holes and the F350 has four holes. Since the F250 towers are slightly cheaper, most guys go with those. If you plan to bolt these on, you can always drill more holes. If you plan to weld them on it makes no difference which you choose.
E5TZ-18183-A 88 F250 Ford part number for taller replacement front shock towers
From the Tech Trivia page - link up top
