for those with mini p/s
elizabeth,co
has the system relieved you of the white knuckle bumpsteer you get in a non p/s 40???
i have the stuff and just havent installed it yet.but i was wondering if i can expect the same bump steer with it.
i run 33x12.5 swampers
:cheers:
I get no bumpsteer with manual steering. Stock sized tires and wheels, though.
YES!! But mine was more of a black-and-blue left elbow from hitting the door, and bloddy ass popped stitches from a badly cut wrist type of bumpsteer. That trip really beat me up, so I deciced to do the mini p/s conversion last winter. No appreciable bumpsteer, I'm very happy with it, but there's not quite enough low RPM assist with my setup, I need a smaller pulley, or I need to modify the pump a little...
nial
yes i know what you speak off.i missed 3 days wheelin in moab this year due to the steering wheel pullin my shoulder outta whack.wasnt payin attention.
so thats cool.is it gonna be better cruisin down the highway at 60 too?
Changing to the mini steering in my truck made an enormous difference. I rebuilt the center arm, relay rod, rag joint and all tie rods at the same time. one hand on the highway is a nice thing.
It took a ton of the wander out of my steering.
cool thats what im lookin for.for the most part its one hand,till i hit some uneven @&@&@&@& in the road then its like i need 2 lanes to control it.center arm,tre's have been done so im good there.
im only so crazy bout this cause i almost piled it up this mornin into a cement barrier cause of it.
I don't have the problem you are talking about. You are welcome to drive my 40 if you want to check it out. Course I have 33 BFG's
Ken
Steering box and center arm were totally worn out on mine, tre's ok. Yes, dramatic difference on highway, too. Are you due for an axle rebuild (knuckle bearings...)? Power steering won't compensate for a worn out suspension.
nial
Mine are 33x9.5 also, definately a factor. Before the p/s conversion I was running crappy 31x10.5, for what it's worth...
nial
The things that made my truck track like crap were:
Shackle lift- even with shims, it never felt right on the road. Lots of wandering and following grooves in the road. And I broke a shim which sent the axle into fits while climbing an obsticle, breaking a center pin. This bent a leaf spring when the ubolts loosened up when the shim bits shot out.
Worn spring bushings and shackle bushings.
Worn rag joint and relay rod end.
I do feel that the power steering (mini) made a huge difference over stock, but there are a ton of variables that may have contributed to it's poor handling.
bump steer has nothing to do with power assist, bump steer is caused by bad steering geometry, slop and bump steer and two very different things. Tie rod and drag link should be parallel to eliminate bump steer.
Crappy suspension is different story.
X2
Exactly correct.
"Tie rod and drag link should be parallel to eliminate bump steer."
Forgive my ignorance, but isn't it the tie rod and relay rod you want parallel? Just curious...
SMALLER PULLEY,
The pulley I used and a few others is a machine pulley
and it is a little smaller in diameter so the RPM on
the pump increases a little.These are Martin,s #
,Martin is the Mfg.
Pulley- 1-B-50-SDS
Bushing- SDS 3/4
hth Bill
You could install ps and still have bump steer with worn out TRE's, bent rods, bad center steer arm and a loose box. I used to have enormous bump steer because of those things on my SO 40. I fixed everything or replaced them and with 33x12.5 and 36x12.5 swampers I could do 70+ down the road and it'd drive straight.
Fix those things first then put on ps.
Yes. Some people call it a drag link, but I guess Toyota calls the drag link from the center arm to the passenger knuckle arm a relay rod.
In any event, the rod from the frame mounted steering component (pitman or center arm) to the knuckle should be parallel to the tie rod between the two knuckles or else you will have bump steer. If this rod is at an angle, the knuckle will turn L and R when the suspension droops and compresses. This is bump steer. Not good.
Slop in the steering components is something else: loose steering.
