For Sale, Trade, or Free!
1F engine decision, sell as a unit or part out
I have two 1F engines and I am going to keep the best of the two.
The one I think I'm going to let go is dated 12/67.
Here is what I know.
Main and rid bearings are STD, but the rods journals may need a good polish or go to 0.010"
Cam has 1 bad lobe
Head has no visual cracks or signs of head gasket issue
Was going to rebuild it, but my brother found me a 2F out of a 87 FJ60
I have a set of new ITM STD rod bearings to go with it.
Front mounts not included.
Dual runner Intake and exhaust manifold included. There is an old 6-1 header that can be included
Was thinking start at $250 obo.
Thanks
Ernie
May be interested in that header if you’d be willing to separate.
I'll go dig it out of the corner and take some pics.
I would probably say $50 for the header.
Looks like it was chrome in its early life.
Tiny dent on the first exhaust pipe at the top and a section at the bottom.
I think k that was done for the Clutch slave cylinder on the driver's side in the late 60 to early 70s fj40s.
I'll take $40 for it based on the condition
Thanks
Ernie
The dual runner intake and exhaust.
I'll just keep the booster vacuum pipe and the side plug shown in second picture
I'll separate these two items from the engine for $60 for both
I would separate head with rocker assembly for $150 obo
It has the EGR port plugs which cam from a Man-a-Fre desmog kit
Engine hook not included.
Would this block be compatible with a '73 F engine?
@TexFJ
Pistons changed to dome for 73
Crank is compatible, with only delta being the harmonic balancer, which was pressed on for 68 to maybe 69
Rod is compatible
Head looks to be the same. Early 67 were siamese design
Block seems to be compatible
Block same from 68 to end of 73.
So the answer to you orginal question, is yes except the domed versus flat piston
