Ok…As some of you already know I am the “heavy weight” tester for the new FOR 3.5” lift kit, produced by Frankies Off-Road in Alabama. I have been running an OME 2.5” HD lift with Rancho 9000 shocks for about 3.5 years. I am installing Slee’s adjustable panhards front and rear a new front drive shaft from him as well to compliment the kit, and set it up right for me. I also plan on using Landtanks castor correction plates to deal with the castor problem. My wife and I are very picky, and it is Teresa’s daily driver so if we were going to spend a bunch of money and upgrade our lift/truck. It was going to be a semi custom setup, I wanted to run 35” with a low center of gravity, better castor correction and the best springs and shocks money could by. I wanted better longer lasting springs and much better shocks; this meant I needed shock adapters in order to run the better shocks. And this kit looked like the foundation for me. The only question I had and have is will it handle the weight I have; especially on long wheeling trips with the family. I received the kit the other day and installed it after work.
Now obviously I have a lot of testing for me to do over the next few months, including installing the Slee stuff (waiting on rear panhard Alvaro has caused a shortage in the country apparently), bigger tires and gearing (haven’t made up my mind on the gearing yet). And I don’t want to come across like, I believe that this kit is the best thing since Slee off-road, having not really tested it but this suspension is like night and day. The difference is incredible!…. It is head and shoulders above OME in initial quality. The sagging that I tried to fix by adding packers (that didn’t work) is now gone. The scary sharp sudden dive into corners that I would get sometimes is replaced by a predicable slight body roll; the whole thing is so smooth, firm and balanced.
I just thought that people should know that so far we are very happy with the move and those that are considering a lift or spring/shock replacement of any kind should at least look at the springs, adaptors, and shocks that Frankie has to offer. I went with a 3.5 to 4” set up for 35s this should give me a little extra room do to the extra weight and chains that I need to put on in the winter in order to get up the driveway. Or you could get the 3” to 3.5” set up, this kit is very versatile, it is not too tall to run 33s you could just not install the bump stops. He also can get you bigger springs for running 37s etc.
Sam
Sam
